1980 F-150 washer pump - Ford Truck Enthusiasts Forums
Old 12-04-2010, 10:45 AM
1980302windsor's Avatar
1980302windsor 1980302windsor is offline
1980302windsor is starting off with a positive reputation.
The windshield washer fluid pump seems to turn on (i hear the humming when i depress the button) but just a trickle of fluid escapes. I am thinking it is the pump (More Information for ANCO 6201)
Does this pump power both fluid nozzles or do i need 2 seperate pumps? Thanks!
Old 12-04-2010, 01:11 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
The one pump powers both nozzels. (Actually one nozzel with two jets)
The problem is most likely the nozzel itself. It gets plugged up VERY easily. I've replaced mine 5 times untill I thought to change the hose from the washer pump to the nozzel as the rubber hose was deteriorating on the inside and causing the nozzel to plug up.
Old 01-18-2012, 01:36 PM
300/6 Freak 300/6 Freak is offline
300/6 Freak is starting off with a positive reputation.
oh thats a good idea! replace that hose! yup thats next on my list! that and figure out why not washer fluid! hardly worked yesterday and not at all today. No sound from the pump when i push the button so I need to check for voltage at the tank and go from there. Thanks for hte good idea to replace that hose though too!
2003 Ford Explorer Washer Fluid Pump mweaver644 Explorer, Sport Trac, Mountaineer & Aviator 2 01-25-2014 11:20 PM
Rear Window Washer Big Sky Excursion - King of SUVs 12 03-17-2010 07:52 PM
Washer Fluid Pump waldrop1965 Ranger & B-Series 13 08-19-2005 01:56 PM
Leaking washer fluid 1081 Explorer, Sport Trac, Mountaineer & Aviator 8 04-11-2005 02:28 AM
'66 F100 - washer fluid pump Matts66 1961 - 1966 F-100 & Larger F-Series Trucks 3 08-11-2003 10:11 AM
Tags
6201, anco
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
