Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 12-04-2010, 08:37 AM
jeronlines's Avatar
jeronlines jeronlines is offline
2000 Ford Excursion
jeronlines is gaining momentum as a positive member of FTE.
F'Burg PSD Mech
I am looking for a good PSD mechanic in the Fredericksburg area. Does anyone have any suggestions? Thanks.
__________________
Jeremy, PAA #105
220. 221. Whatever it takes.
'00 Ex LTD: 7.3, 4WD, 160k+, AFE Big Boost w/ RDP cover, 4" Dynaflow after stock muffler (PO mod, need to finish)
  #2 (permalink)
Old 12-06-2010, 06:55 AM
MissIndependent's Avatar
MissIndependent MissIndependent is offline
Garage is empty, add now
MissIndependent is gaining momentum as a positive member of FTE.MissIndependent is gaining momentum as a positive member of FTE.
DIY? lol, come on guys...speak up, i only know a good shop in vb!!
__________________
"she's not crazy, just a little misunderstood"
1996 F250 XLT 7.3L PSD SC/LB 4x4, auto, 4.10s, 4" suspension lift on 37" Goodyear Wrangler MTs, 6637 air filter, 208k+ mi and counting
Plotting: stacks, gauges, tw chip, cat/muffler delete, and more that won't fit
  #3 (permalink)
Old 12-06-2010, 02:36 PM
Rubenk's Avatar
Rubenk Rubenk is offline
Rubenk is starting off with a positive reputation.
What are you needing fixed or worked on?
  #4 (permalink)
Old 12-06-2010, 09:44 PM
Blue Chevy's Avatar
Blue Chevy Blue Chevy is offline
Blue Chevy is starting off with a positive reputation.
Quote:
you must be talkin bout Merchants tire an auto on indian river
__________________
-Mike
  #5 (permalink)
Old 01-31-2011, 11:42 AM
JonathanN's Avatar
JonathanN JonathanN is offline
1999 Ford F-250
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Diesel Power of VA is pretty good... but I would DIY. There's enough on FTE to get you the info you need as well as people around you to help you out.
Here's a BUMP for ya!
__________________
Jon
Early 1999 F-250 Lariat 4x4 w/7.3L PSD, AT, SC, LB, 315/75/16's on 16x10's, 4" Lift, 4" Exhaust, HPx, Regulated Fuel Return, Hutch/Harpoon, NVK4 PCM, John Wood Valve Body, 6637 w/Pete's Cover, CCV, EBPV Delete, DP-Tuner, IssPro's - 332,000 miles!
Truck Pictures
  #6 (permalink)
Old 05-22-2011, 06:39 PM
cmdevildog16's Avatar
cmdevildog16 cmdevildog16 is offline
cmdevildog16 is starting off with a positive reputation.
i found one close to Fburg that im going to try out they come highly recomended from the PSD owners around here...they are actually in Morrisville VA wich is probably 15 or 20 min from Fburg...its Digges Automotive Inc. ill let ya know how they are once i deal with them
Tags
dealer, fburg, ford, va
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
