2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
class V hitch
Old 12-05-2010, 07:30 PM
BigMick's Avatar
BigMick
BigMick is offline
class V hitch
Started poking around my EL 4x2 and noticed that it has a class V hitch and no transmission cooler. Aftermarket add on?
Mike
Old 12-05-2010, 08:29 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
no
all the Expy's come with a Class V hitch and a 4 pin harness. The Tow Package is when you get the 7 pin harness and the Trans Cooler.
Old 12-06-2010, 06:03 AM
chuck s's Avatar
chuck s
chuck s is offline
The 7-pin outlet on the rear is a hint you have the HD Tow package.
My factory HD Tow hitch label says it's Class IV, though, not Class V.
Class IV hitches are for up to 10,000 lbs. GTW and 1,000 to 1,200 lbs. of tongue weight. This type of hitch is usually a weight-distributing hitch.
Class V hitches are for extra heavy loads greater than 10,000 lbs. GTW and more than 1,200 lbs. tongue weight. This type of hitch is usually a weight-distributing hitch. This type of hitch may have up to a 2-1/2 inch receiver with a 3/4-inch pinhole. Typical uses might be to tow a car trailer, horse trailer or unusually large boat or camper.
-- Chuck
Old 12-06-2010, 12:46 PM
BigMick's Avatar
BigMick
BigMick is offline
Thanks Chuck,
Your becoming my go-to guy for knowledge.
Diesel_Brad
22
03-21-2015 12:33 PM
Jarvis250
1999 to 2016 Super Duty
09-25-2008 07:08 PM
cumminpwr11
08-14-2006 02:09 PM
grevalaz
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-26-2003 01:49 AM
Quick Reply: class V hitch
