No Power, No Turbo boost Under 2G RPM - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-04-2010, 02:24 AM
Pro Form Pro Form is offline
Pro Form is starting off with a positive reputation.
2006 F-250 6.0. 4" exhaust straight from turbo, Sinister Delete kit, Banks Intake, Edge Tuner.
First noticed exhaust louder, more throaty (similar to gas dual piped V8) upon start, after 1-3 minutes, turbo kicked in and whistled like previous. Problem continued with minor inconvenience (should have known to look into this). This week, started truck in cold (live in MN) and loud hard idle never stopped. No power under 2G RPM and no turbo boost until +2G RPM, Then turbo boosts and drives, runs like normal. Low idle truck is loud and sounds like gas piped V8. Thinking I might have a turbo that is only working in once or two stages. Thoughts? Thanks.
Old 12-04-2010, 07:34 AM
nfntruth nfntruth is offline
nfntruth is starting off with a positive reputation.
Wow, that sucks man. I was thinking I had problems, I was having the opposite. I was getting up to 10lbs of boost at 1500 RPMs while eggshell driving. Dealer said the vanes were sticking and told me to add some cetane booster and 'get on it' everyday until it stops smoking. Worked like a charm.
But you say yours works fine over 2000rpms? Could be a software problem, if the programming that controls the geometry of the vanes in the turbo is screwed up for <2k rpms....and I notice you have some mods that tinker with factory settings. Could be a problem there. Try flashing back to stock and see what happens.
Old 12-04-2010, 07:41 AM
cliles55's Avatar
cliles55 cliles55 is offline
cliles55 is starting off with a positive reputation.
I was talking to a guy yesterday at the Ford house and discussed a turbo problem he had with his. Whichever model it was, the turbo had variable vanes; lost power and turbo was whining. The dealership found corrosion in the area of the variable vanes; split the turbo, cleaned it out and sent him on his way. He mentioned it was the "dirty side"; perhaps the exhaust side inlet to the turbo.
Hope this helps and that you are still in warranty,
Curt
Old 12-04-2010, 10:30 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
When it does it under 2k rpm, does it roll out the black smoke and then get t driving normal?
Old 12-04-2010, 01:06 PM
Curt
My dealership told me cleaning the turbo was not covered by warranty?
Old 12-04-2010, 01:33 PM
cliles55's Avatar
Quote:
He bought the truck in Central Texas and was enroute to CO; truck was acting up in Albequerque, NM. The dealership there hooked him up; he paid warranty $100 deductible (but received a check back from Ford afterwards). I'd call that good customer treatment, warranty or not. I want to say he mentioned "emissions", perhaps that was the difference.
I'd say they deserved their 72-bay service department with service like that!
Old 12-04-2010, 04:15 PM
lakewood's Avatar
lakewood lakewood is offline
lakewood is gaining momentum as a positive member of FTE.
This just happend on my 05, except i didnt see boost till 3k rpms, and at 3k i would only get 5psi. Try getting the turbo cleaned, and the unison ring checked. if cleaning returns the truck to normal you should be fine. But if after being cleaned it loses boost again, its time for a new turbo. This is what happened to my truck, had turbo cleaned, it gummed up again and a new turbo was needed. Good luck
Old 12-06-2010, 03:59 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03 SoCalSuperDuty03 is offline
SoCalSuperDuty03 is gaining momentum as a positive member of FTE.SoCalSuperDuty03 is gaining momentum as a positive member of FTE.
ProForm... I am not sure if the '06's have an Exhaust Back Pressure sensor in the loop, but if they do, check it. I have had three trucks with the EBP's go bad, and the symptoms are EXACTLY what you are saying.
Upon startup, no turbo whistle (sometimes not until you drive down the street), no boost below 2000 RPM, then runs hard like it should.
My personal truck did this and I couldn't figure it out (all VGT tests performed) until I hooked a Vehicle Data Recorder to it and took it on a couple hundred mile drive.
In addition, even after my personal truck was warm during long drives, if I was off the throttle descending a hill, and then stood in the throttle to accelerate, my truck would lay down for 4-5 seconds, suddenly build boost and run normal. This would not occur each time, but the cold start/no boost problem definitely did.
The other two trucks came to me after they were told both needed turbocharger cleaning or replacement. Neither did. Obviously some trucks need turbos, but spending $1500-2000 when that actually wasn't the problem would suck!
7.3 idi turbo boost Jesse73iditurbo 1987 - 1996 F150 & Larger F-Series Trucks 13 05-15-2016 04:38 PM
horribly running after go-go intake manifold and turbo clean surfaccing 6.0L Power Stroke Diesel 7 04-08-2013 02:55 PM
Just rebuilt, put in arp studs, gaskets, the works - now no boost at all from turbo. superv10 6.0L Power Stroke Diesel 2 05-11-2012 12:18 AM
Loud whoosh under hood. ROBBINthaHOOD 6.0L Power Stroke Diesel 11 11-22-2011 11:55 AM
Wicked wheel install gone bad randomhero1172 1999 - 2003 7.3L Power Stroke Diesel 31 06-18-2008 06:44 PM
Tags
2000, 2004, 60, boost, booste, booster, f150, f250, ford, power, rpm, truck, trucks, turbo, turboboost
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
