Wipers work on high only - Ford Truck Enthusiasts Forums
Old 03-02-2003, 12:06 PM
alicenfred alicenfred is offline
alicenfred is starting off with a positive reputation.
Question Wipers work on high only
My 91 Ranger wipers only work on high speed and will not park when shut off. The low & intermittent speeds are completely in-op. Can anyone help me diag. this? Thanks
Old 03-02-2003, 01:04 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
I don't know your truck but usually the lack of low speeds is a resistor assembly inside the ductwork that opens up. It drops the voltage to the motor. The lack of park function could be the switch or the motor.
Old 03-02-2003, 05:19 PM
kioolt kioolt is offline
kioolt is starting off with a positive reputation.
The lack of low speed in the motor that has been seen on this site is for heater/AC blowers not the wiper motors. Wiper motors DON'T have resistors for the lower speed. They use just part of the motor winding for the lower speed.
Old 03-02-2003, 07:36 PM
Mike W's Avatar
That's what I get for reading before I'm awake.
Old 03-02-2003, 07:52 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Sounds like the speed governor for the wiper system.
Old 03-03-2003, 01:18 AM
Thanks, it was a bad speed governor
Old 03-03-2003, 01:14 PM
jbalestri's Avatar
jbalestri jbalestri is offline
jbalestri is starting off with a positive reputation.
Is that a dealer item?
I am having the same problem, thought it was the switch and that didn't help. Was gonna buy a new motor, but if the speed governor thing is replaceable, I'll go that route.
Thanks
Old 03-03-2003, 01:54 PM
Yes it's a dealer item.
There are aftermarket systems but they are cheap by comparison.
Old 03-03-2003, 04:25 PM
The governor is under the dash to the right of the steering col.and it cost is about $25.00. Just in case you were wondering.
Old 03-03-2003, 04:43 PM
jbalestri's Avatar
Thanks y'all.
That'll still save me about $25.
Again, thanks for the advice.
Old 03-03-2003, 11:44 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
PM or e-mail me.
Old 03-07-2003, 07:13 PM
ranger6 ranger6 is offline
ranger6 is starting off with a positive reputation.
Seen that problem about a year ago w/my 91. In the helm manual for my truck it says, if the wiper works on high only then the switch is bad. There's no need to check for pwr or a wire going to gnd. It's the switch that has a wiper that runs on a rheostat. The rheostat is taken out of the loop when the switch is placed on high.
Old 03-27-2011, 11:48 PM
weathergeekee weathergeekee is offline
weathergeekee is starting off with a positive reputation.
Thanks for all the posts on this. I pulled out the delay module and found diode D2 with bad solder joints to the circuit board on the heatsink bracket side. Diode D2 feed the relay that completes the low speed circuit and when the solder joints break, no low speed and no delay. I resoldered all three connections to D2 on the circuit board and added some small wires wrapped around the protruding leads to the relay leads in parallel for extra connections (just in case the PCB joints break again). D2 is located right next to the relay and has a U-shaped bent metal heat sink bracket with two bend tangs soldered to the PCB. After soldering and adding the parallel wires, reinstalled and it works like new. But before I read these posts, I had changed the wiper motor and still had no low speed so was scratching my head thinking it was the switch. Now I have a new motor and 'better than new' delay control module so should be good for many years.
Wiper switch wiring HoustonDave 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-09-2016 11:47 AM
I don't get it? Intermintent wiper upgrade won't work Old Brown Truck 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-19-2016 06:32 PM
Wipers only work on high whyjay 1987 - 1996 F150 & Larger F-Series Trucks 14 12-08-2008 07:29 AM
prob w\ '87 intermittent wipers drivingbob 1987 - 1996 F150 & Larger F-Series Trucks 5 12-28-2006 03:09 AM
1998 Explorer intermittent wiper problem Bob Cook Explorer, Sport Trac, Mountaineer & Aviator 6 12-14-2006 04:03 PM
Tags
2002, 93, explorer, f150, f250, ford, high, ranger, runs, speed, window, wiper, wipers, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
