Wondering whats wrong here. My 2004 6.0L is getting 350-400miles to a tank....
So Ive had my new 04 Ex for a little over two weeks or so now and Im more than shocked. Im not getting the same kind of fuel economy that my 05 PSD was getting....
The specs,
2004 PSD 6.0L,
108,000 Miles.
Bone stock.
Valve covers still are oem International the do not say Rebuilt on orange International stickers. They are Blue and says 2004 Motor.
Now im driving always highway miles and average 100-180 miles per day min somedays more.
Now I did swap the stock tires for 315 but I have lost over 300 miles to a tank and these tires were the exact same ones I used to have on my 05.
SO my question is where can I start to figure out whats causing the loss in fuel economy. Once I get my emission test tomorrow im pulling the factory exhaust and installing the turbo back Billy Boat 4 inch exhaust and the cat delete will be installed.
Anywho, Im also going to do a full flush on the coolant as well as the previous owner decided to install prestone green coolant no the ford gold coolant. Then Ill do a full fluids flush.
Oh I also forgot that I notice that when I do put it to the floor its feels almost like sometimes its not wanting to and it will not down shift from fourth into third or fifth into fourth where my 05 would. Is there a possibility that there is a firmware upgrade for the ECU and PCM or the BCM?
The specs,
2004 PSD 6.0L,
108,000 Miles.
Bone stock.
Im usually not hitting 80, Im floating around the 65-70mph.
Hi, welcome to the 6.0 Excursion. I have an '04 6.0 Ex and I usually get 600-700 miles to a tank, and 300-400 if I pull my travel trailer.
I did have a brake problem once that caused my mileage to go way down. One of the calipers was sticking and the brake was lightly applied all the time. The cure was nothing more than pulling the caliper and cleaning the rust from the pins and replacing it. I only knew it for sure because it was a front caliper and once it stuck in a tight applied condition which lead to pulling to one side. I would think a rear caliper would do the same pulling but not as noticeable in the steering.
It's just a thought but it made a huge difference in MPG without really noticing anything was wrong with the vehicle.
There is an OEM upgraded parts kit for the sticking front calipers its a known problem. a search will find you all the needed info. If your FICM has an updated flash it can kill a few mpgs easy. go to Power Hungry Performance and get the FICM flashed to a better version... Ford did the MPG and performance killling update to reduce warranty claims
no the FICM (Fuel Injection Control Module) was removed from the PCM on the 6.0 engine. PHP will send you the programmer and the files to reflash your FICM then when you return the programmer you get your deposit back for the Programmer.. here is the link Power Hungry Performance - FICM Reprogramming And I can gurantee that your FICM was re flashed by the dealer when you had the EGR and cooler work done...
superv10
11-15-2019 02:18 PM
BryanStein
07-27-2013 01:52 PM
