1962 ford grille
1962 ford grille
Has anyone polished a 62 grille? I came across a 62 aluminum grille which was very straight. I took it to the shop for polishing. This is one of the hardest grilles to polish due to lack of support on the long areas. Unlike 61 63 64 65 66 grilles, there is not much support. This was a challenge, the result's? One beautiful grille.
62 aluminum grille
Here's a couple of pictures of the 62 grille.
<TABLE border=0 cellSpacing=0 cellPadding=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD bgColor=#dfdfdf colSpan=2 itxtvisited="1">Description: </TD></TR><TR itxtvisited="1"><TD bg*************** colSpan=2 align=middle itxtvisited="1">
</TD></TR></TBODY></TABLE>
What you think?
What you think?
on
Mounted on a truck there are no weak spots as there are 15 mounting tabs. When polishing on a big polisher your holding the grille applying gentle preasure if not carefull you can warp it. There are only two upper and lower facial braces holding the center horizontal area. The horizontal bars can get real flimsy and twist real easy.
