4x4 vibration/noise, 04 F250
HI i have a 2004 ford f250 6.0 diesel i just put new warn locking hubs on it as well as the CV centering ball seat in the double cardan joint and all new u joints in the front drive shaft every time i put the truck in 4x4 i get a slight vibration in the front end area under acceleration and a squeeking rubbing sounds (sounds kinda like a bad u-joint) when braking or coasting at lower speeds, and this does not occur when in 4x4 and hubs unlocked, in 2wd with the hubs locked or in 2wd hubs unlocked. I took my truck to a local shop and they couldnt figure it out and they said the u-joint on the axles seemed to be in good condition. Can any one help me figure this out Thanks!
My under standing is when the truck is in 4x4 with the hubs unlocked everything spins but the wheels are not engaged to the axles which would mean the squeeking would be coming from the hubs but they are brand new. Makes no sense to me.
Brian460
1999 to 2016 Super Duty
12-11-2009 07:28 PM
