2003 F250 6.0 liter Diesel Lariet driveability issues - NO POWER - Ford Truck Enthusiasts Forums
Old 12-03-2010, 04:12 PM
I am New to Ford I am New to Ford is offline
I am New to Ford is starting off with a positive reputation.
I have just made a purchase on a 2003 F250SD Lariat Powerstroke 6.0L diesel with an Automatic trans and 4x4 Super-cab with the suicide doors. I have been test driving it for the last 5 weeks thanks to the previous owner being a friend of mine! I really am starting to love this truck even-though I have been a Chevy guy practically all my life! The only issues with this truck is that there is a slight loss of power as I step in to the accelerator pedal, the truck seems to flatten out until I feather the pedal then it shifts and takes off strong. It does this in every gear and it will shift every time I feather the pedal. When the truck is fully warm it performs MUCH better but NOT perfect. I am not very familiar with Ford's Diesel's I thought and believed that the High Pressure oil pump was at fault!???? I just dont know. My friend showed my the trucks service history! It had its injectors replaced twice the head gaskets and EGR tube were replaced as well as the fuel pump along the frame!
I also have the drivers side exhaust pipe on order as it leaks at the flex pipe. I made a stainless steel clamp to go over the leak that helps seal it until the new part gets here! The truck starts well cold or hot, I make sure that the glow plugs cycle at least twice in the morning or after a long cold soak! I am seriously getting between 13 and 15 MPG U.S. even when the truck is not running as well as it should be!
Any idea's!
Old 12-03-2010, 04:59 PM
Sorry I accidently sent this duplicate thread! I tried to erase it but I obviously didn't!
Old 12-03-2010, 08:15 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
Just know that the early 6.0 in 2003 and 04 have a troubled past.
As long as your friend is honest with you and shows you ALL service paperwork/engine and drive-train(transmission) warranty work
Get an OASIS report!! It's free from Ford dealer!
Where are you located?
good luck!
Old 12-03-2010, 08:43 PM
bayou barataria bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
If it was the hpop it would not start. Check out the 6.0 forum. Definitly get the oasis report, if it has a lot of repairs stay away.
Old 12-04-2010, 09:50 AM
Thanks for the info. I will get the Oasis report! I really do not think that my friend would intentionally sell me anything that he thought was bad! I have known him for many years and it is not his nature! This truck was owned by him since new and it is All hi-way miles! It shows 326542 km (202903 miles). All of the warranty work was done in the first year of ownership when I think the Ford Techs here (maybe everywhere) were still guessing at the problems! They changed the whole set of injectors twice with-in 3 months when the truck was 9 months old! The oasis report should be a more complete history I am thinking! Thanks again for the info.
Old 09-22-2011, 01:00 PM
rockstar69 rockstar69 is offline
rockstar69 is starting off with a positive reputation.
Hi There new at ford.my truck was doing the same thing.Have you looked at the high oil presser pump.That runs the injectors.With oil presser.I have 115k on my 2003 6.0.It went out.It will not start.....That is a big job to change on a 03.Ford wants 13hrs to do it.The part is spendy to. around $850.00 and up.I am looking on the form to see if any one has changed that part.Lookinf on my chilton does not give a good way to change.
Old 09-22-2011, 03:06 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
2004 6.0 has no power and will not accelerate aussiebilly 6.0L Power Stroke Diesel 13 12-31-2016 03:08 AM
2004 Ford Excursion 6.0L - PROBLEMS - No Power, Won't Shift, Black Smoke, blindjudge04 6.0L Power Stroke Diesel 4 02-25-2015 08:38 PM
F250 Transmission shifting Problems. Need a fix ASAP! Farmin250 1987 - 1996 F150 & Larger F-Series Trucks 8 09-03-2012 07:03 PM
Starting to think I have a power-joke diesel patb121185 6.0L Power Stroke Diesel 12 08-23-2011 04:20 PM
2003 F250 6.0 liter Diesel Lariet driveability issues I am New to Ford 1999 to 2016 Super Duty 7 12-06-2010 04:58 PM
Tags
2003, 2007, 60, battery, diesel, driveability, f250, f350, ford, issues, lack, lacks, lier, power, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
