Eagle crank and rods vs. stock crank, rods - Ford Truck Enthusiasts Forums
Old 12-03-2010, 08:42 AM
77custom408 77custom408 is online now
77custom408 is starting off with a positive reputation.
Is the cost of a new Eagle cast crank $239+ tax and shipping plus Eagle Forged I beam rods $365+ tax and shipping worth buying over using Ford factory crank and rods, how strong is the stock stuff. I would like to put that money toward something else toward my engine but will buy the Eagle set up if i need
Old 12-03-2010, 09:11 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
I'd stick with the factory crank if you aren't going to stroke it.
Old 12-03-2010, 09:35 AM
How about the stock rods are they strong enough for a performance rebuild
Old 12-03-2010, 11:53 AM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
Factory crank and rods are good for around 500hp with no problems, The forged H beams that I had in the 429 build are actually buried in a box somewhere, the 460 in the video is stock 460 crank and rods, around a 1976'ish model.
Figure if you are looking around $400-450ish for the stock rods (shot peen $15 per, ARP bolts $65, resize $20 per, magnaflux $3-5 per, press fit pistons $8-10 per) the $365 for Eagles are the better price, even with S/H, its a better rod, and on top of that its a floating design instead of press fit.
The shop you are using may have better prices and if thats the case you may want to stick with the factory rods, if not, then go with the stock crank and use the eagle rods.
Old 12-03-2010, 12:06 PM
I think i am gonna use the stock crank and get some Eagle rods with SRP pistons, Edelbrock aluminum heads, RPM intake manifold and the FAST #30226-kit, i am minutes from ordering my Xtreme 4x4 262H cam and i think i finally know which way i am gonna go with this motor. Thanks
Old 12-03-2010, 12:18 PM
L. Ward's Avatar
Quote:
You are more than welcome, and keep us posted (w/pics if you can) as you proceed!!
Old 12-20-2010, 05:43 PM
littlehusky's Avatar
littlehusky littlehusky is offline
littlehusky is starting off with a positive reputation.
FWIW factory cranks are good for a lot more than 500. The factory rods are not as good as the cranks.
Eagle cranks (cast steel) are a hell of a lot weaker than the ford cranks.
eagle I beam rods 6.605 rods discontinued dying breed racing Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 05-19-2015 03:47 PM
a new stroker equasion Stratosss 1967 - 1972 F-100 & Larger F-Series Trucks 10 01-14-2015 08:30 AM
Wheel selection help KIKKUP 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-30-2013 07:35 PM
need opinions on 331 randys85 Performance & General Engine Building 21 09-28-2013 02:48 PM
Building My firsts 460... Looking to make at least 1100 H.p. shazam Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 25 11-19-2002 02:33 PM
Tags
250, 302, 460, 4x4, beam, build, crank, crankshaft, crankshafts, eagle, ford, forged, problems, resize, rods, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
