how to change lower radiator hose? - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-12-2014, 04:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
Print Wikipost
Old 12-02-2010, 12:37 PM
driverman1 driverman1 is offline
driverman1 is starting off with a positive reputation.
How do you get the radiator end of the hose lose on a 2000 exp?
Old 12-02-2010, 02:44 PM
ALLDATAdiy INFO ALLDATAdiy INFO is offline
Former Vendor
ALLDATAdiy INFO is starting off with a positive reputation.
Are you using a hose clamp tool? They help, or are you trying to get the tranny cooler line off?
Old 12-02-2010, 04:03 PM
Big Greenie Big Greenie is offline
Temporarily Deactivated
Big Greenie is gaining momentum as a positive member of FTE.
Quote:
So are you just spamming this forum? I have just read three of your responses in three different threads and you have been no help at all. Do you have any idea what you are talking about or are you just trying to sell people repair manuals? I am thinking it is the latter.
Old 12-02-2010, 04:13 PM
97ExpGuy 97ExpGuy is offline
97ExpGuy is gaining momentum as a positive member of FTE.
Quote:
The lower radiator hose at the radiator is tricky because it has some sort of spring-loaded connector if I remember correctly. There is a warning label that mentions it. What I did was cut the lower hose off with a razor blade knife (because I was replacing the hose anyway). Once I did that, you should be able to see the ring that is under tension on the radiator. Instead of cutting it off, I put Vaseline on the inside of the hose and slid it on over the ring. It took some muscle to do it, but the new hose finally went on. Tightened down with a screw-type radiator hose clamp and whoa-la. No leaks. Hope this helps.
Old 12-03-2010, 09:15 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
There's a little metal tab that you have to bend out, then turn the hose 45 degrees CCW, and then pull your arm off (it's a real bear). It helps significantly by giving you a lot of working room if you first remove the plastic shroud out of the driver's wheel well.
Old 12-03-2010, 09:16 AM
Quote:
He's a site sponsor so he's allowed to.
Old 12-03-2010, 06:30 PM
Now I have the tab bent in and I can't get the hose to turn. Maybe I BENT IT THE WRONG WAY I bent it in so its even with the hose it looks like it should turn but its not moveing
Old 12-03-2010, 08:19 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
lower rad hose
just cut it off
Old 12-04-2010, 02:07 AM
There is a notch in the metal ring down there for the tab to fit into. If the tab is in the notch then the hose WILL NOT turn. You have to bend the tab away from the radiator so that it is NOT in the notch.
Old 12-05-2010, 06:09 PM
I bent the metal tab back to the hose still wouldn't move. So I took a screwdriver and tap it with a small hammer moved it till it got around where I couldn't reach the notch on the end still couldn't move it by hand. Ended up cuting the hose off near that band at the end then I gentle bent the four metal tabs up that was in the hose finally it come off. What a pita. Thanks for all the replys
Old 12-08-2010, 07:25 PM
removing lower radiator hose-just cut it off
I tried to tell ya!
5.0 coolant leak MisterCMK 2009 - 2014 F150 3 02-09-2017 08:10 PM
How much coolant? sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 4 03-26-2016 04:13 PM
Heater Hose 5851a 1987 - 1996 F150 & Larger F-Series Trucks 2 06-30-2014 12:51 AM
Radiator water hose leak Wrench Bender 117 1999 to 2016 Super Duty 1 11-10-2013 12:29 PM
2007 expedition lower radiator hose gahoghntr 2007 - 2014 Expedition & Navigator 0 01-31-2011 10:30 AM
Tags
1998, 1999, 2000, 2006, 54, change, diagram, expedition, f150, ford, hose, lower, mountaineer, radiator, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
