Need some help, 87 ranger
i know that they are usually located on the block, and this is what puzzles me, but the thing is this is the only sensor that is identical to the one i pulled off of my truck,btw it came off the intake manifold
http://www.rockauto.com/catalog/moreinfo.php?pk=2397508
im now confused but either way im going too the junkyard tomorrow to try to pull it off another truck...
ill keep you posted, again thanks for the help g_k50
yeah well that picture is if a knock sensor and the oem number matches perfectly, idk man, its weird from my experience other knock sensor have been screwed onto the block just as g_k50 stated, but this one was screwed onto the intake manifold, so i was a bit confused, but ill be leaving to the juckyard in about 30 min and i hope i find it of another ranger,
i hope everything goes well, ill be back later with another update,
spitfire...
spitfire...
i replaced the knock sensor and my truck is still runnning the same, i have noticed a small difference in when in idle the truck doesnt bog and turn off, i suspect that there is a vacuum leak somewhere in my truck i just have to find it which is going to be painful and tedious,
the truck still bogs when i am accelerating it just starts kicking and bogging on me
any other ideas?
spitfire...
any other ideas?
spitfire...
ethanshuler97
06-14-2016 12:48 AM
Spitfire0450
01-28-2016 12:46 AM
Matthewap44
1983 - 2012 Ranger & B-Series
09-19-2015 04:22 PM
lumberjack_964
09-03-2013 08:30 AM
1987, 23, bmc1, ca, carbuertor, carburator, carburetor, diagram, e57e, e57eca, ford, knock, liter, motorcraft, pictures, ranger, sensor, vacuum
