Headlights flicker - Ford Truck Enthusiasts Forums
Headlights flicker
Old 12-02-2010, 10:19 AM
drdave drdave is offline
drdave is starting off with a positive reputation.
Headlights flicker
My 2002 F150 Supercrew headlights have begun to flicker at approximately 30-45 second intervals. I haven't noticed if any of the interior lights also flicker or if the volt meter changes when it occurs. The alternator appears to be charging since I checked it while running. Any advice?
Old 12-02-2010, 11:32 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
But it prob on it's way out..... how old are the batteries? Put a voltmeter on the Alt output to see if it's steady or varying.
Old 12-02-2010, 06:39 PM
I'm pretty sure the battery is old and I will try to check the alternator output if there is a simple way to do it. Suggestions?
Old 12-02-2010, 08:30 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Just put a good meter across the battery with the engine running. You should have around 14 volts on the battery.
Keep an eye on the dash voltmeter when you have the flickering problem. That will narrow it down to a system voltage problem, or a problem with the headlight circuit.
Old 12-05-2010, 06:40 PM
The battery charge reads 14.5v when the engine is running so the alternator must be ok. I checked the volt guage when the lights flicker and did not notice ANY drop/change when the flicker occurs. Could it be the aftermarket fog lights or a ground strap problem? The fog lights have never caused a problem in the 5+ years they have been installed?
Old 12-05-2010, 09:09 PM
Franklin2's Avatar
Disconnect the foglights temporarily and see if the problem goes away. If it does, it may simply be a poor ground to the foglights.
Old 12-19-2010, 05:15 PM
I let the truck sit for a week and the battery showed 11.7 volts. I decided to go ahead and get a new battery since this is the original (Motorcraft) thinking it may the problem. It wasn't.
The next time I drive the truck I will disconnect the fog lights to see if that is the problem.
Old 12-22-2010, 09:10 AM
Disconnected the fog lights and the flicker still occurs.
Old 12-25-2010, 07:06 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
In older Fords the culprit was the headlight switch assembly.
It had a circuit breaker that would cause a flicker.
I'll have to see if that is still a possibility.
http://www.35thatr.org/Tips/HeadlightsFlicker.htm
Old 01-21-2011, 04:25 PM
I believe that I may have solved my flicker issue. I was also having an issue with the ABS light occasionally coming on. I finally found that the right front ABS sensor was touching the exhaust manifold and melting/possibly shorting. I replaced it and my ABS problem disappeared. Now that I have driven it at night the flickering also seems to have cleared up.
Halp! Intermittent high beam flickering mountain dewd 1973 - 1979 F-100 & Larger F-Series Trucks 26 07-16-2016 09:55 PM
GEM module? newfordy 1997 - 2003 F150 4 11-09-2014 07:29 AM
headlights flickering 300sixnick 1973 - 1979 F-100 & Larger F-Series Trucks 30 01-21-2014 12:06 PM
battery light flicker?? 036.0stroke 6.0L Power Stroke Diesel 4 09-25-2013 11:07 PM
light flicker GaryWestII Escape & Escape Hybrid 0 09-11-2011 12:14 PM
Tags
2001, 2003, 99, dashboard, duty, f150, f250, flicker, flickering, ford, headlight, headlights, interior, navigator, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
