Instructions for installing Front and Rear main seal? - Ford Truck Enthusiasts Forums
Old 12-02-2010, 02:16 AM
holdendaniels holdendaniels is offline
holdendaniels is starting off with a positive reputation.
I am looking for instructions and tips for installing the front and rear main seal. I do not have the special tool. Any work arounds or alternative ways of getting the wear ring and seal on. The new oem seals come with a wear ring.
Old 12-02-2010, 06:28 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Send Cheezit or MChan a PM and ask for the instructions and tips on installing them CORRECTLY otherwise it will leak. It's not quite straight forward IIRC.
Old 12-03-2010, 05:06 PM
I am surprised I have not gotten any instructions or tips. People on this site have done it and usually share their experience. I followed npccpartsman advice. The reply was they have the tool and that's how they install the seal. I did a search for the seal tools, cannot find any. Was looking to see if anyone had anything to add. I am going to be installing the seals tomorrow. Still looking for any help. Thanks!
Old 12-03-2010, 05:50 PM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
I tried to put the engine assembly pdf link in here but it won't upload so here is the tool part numbers.Front seal installer 303-761 rear seal installer 303-770.I will try again to get the pdf to up load.
Old 12-03-2010, 06:14 PM
brickie's Avatar
SPX Motorcraft - Detail: 303-770 - Installer, Crankshaft Rear Seal and Wear Ring Here is s site with the tools,the pdf won't up load.
Old 12-03-2010, 09:36 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
On the rare occasions that I've had to install either seal, I can honestly say that I can't personally see a way to properly install them without using the proper tools mentioned above. If you try to drive the seals in using a generic driver with a hammer, you risk doing damage to the new seals.
Old 12-04-2010, 09:36 PM
Just to follow up: I installed the front and rear main seals today without the the ford seal tools. I put the front main seal wear ring on the crank with a piece of 2x4 and a hammer. I added high tensile strength (red) locktite to help seal the ring. I also used the 2x4 to put the seal inside the front cover and bolted it onto the engine. On the rear, I put the seal into the rear engine cover with a 2x4 and bolted it onto the engine. I then pushed the rear main seal wear ring onto the crank with the adapter plate that bolts on to the crank underneath the ring gear. The rear main seal comes with a black plastic spacer tool that helps seat the rear main seal wear ring flush with the rear engine cover. I think you can install these seals without the proper tools just take your time and make sure the seals are going on straight. The engine is back in the truck with the torque converter, bell housing and engine mount bolts torqued. Tomorrow, I start bolting everything back to the engine.
Old 12-04-2010, 09:51 PM
brickie's Avatar
Good on ya,hope it holds oil.Thanks for the follow up.
Replacing front main question Farmboypowerstroke 1999 - 2003 7.3L Power Stroke Diesel 4 03-05-2014 12:28 PM
Oklahoma City Anyone Crank/Main seal Install tools? creator 6.0L Power Stroke Diesel 43 10-22-2012 11:47 AM
6.0 Rear Main Seal basket1021 6.0L Power Stroke Diesel 2 09-01-2012 06:27 PM
REAR AXLE SEAL WEAR RING pacrewchief 1987 - 1996 F150 & Larger F-Series Trucks 3 06-09-2012 10:12 AM
rear main seal - wear flange nibiru Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 02-08-2011 08:08 PM
Tags
1967, 60, 96, duty, ford, front, inline, install, installing, instructions, main, ranger, rear, seal, super, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
