Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-02-2010, 12:21 AM
Irisher Irisher is offline
Garage is empty, add now
Irisher is starting off with a positive reputation.
1967 Econoline Timing
I have a 1967 Econoline with a 240 V6. When I turn it off it does the spit and sputter. Does anyone know what the timing on this engine is? Also, how difficult is the Carb to rebuild? I'm from the VW side of vans, so this whole experience is all new.
  #2 (permalink)
Old 12-05-2010, 09:12 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
Timing depends on the transmission you have.
If you have a manual trans the timing is 6 degrees BTD.
If auto. it is 10 dedrees.
Now if you set them and later the timing is off again after some driving. That is usually a sign the timing chain and gears are wore. So I would replace them if the timing does not hold.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #3 (permalink)
Old 12-05-2010, 08:10 PM
Thanks. That is really really helpful. I am going to check it tomorrow. Thanks again.
  #4 (permalink)
Old 12-26-2010, 06:43 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
timing is not all that needs to be checked. As the points wear the dwell changes, and as the dwell changes so does the timing.
The 240 has timing gears, if they are worn the timing marker will bounce around and not stay on one number.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
