EBPV question
Old 12-02-2010, 12:07 AM
mongo12's Avatar
mongo12
mongo12 is offline
EBPV question
So i disconected the plug for the exhaust valve and now the MIL is on and i want to know how i can run w/o the valve hoked up and no check engine light, i like the mileage when cold.
Old 12-02-2010, 08:25 AM
Hussler's Avatar
Hussler
Hussler is offline
Which plug did you disconnect? If you disconnected the EBP Sensor (3 wires) that will disable the EBPV but the CEL light will come on. If you disconnected the 2 wire plug just below the turbo that also disables the EBPV, PCM will store a code but the CEL should not come on. If you have a Cali truck the CEL might still come on with the 2 wire connector disconnected .. I don't know.
Old 12-02-2010, 10:33 AM
mongo12's Avatar
mongo12
mongo12 is offline
well for a guess, you are right on the money. It is a California tr5uck and i did disconnect the two wire plug. I am wondering if i can place resistor in the plug so it can trick the computer?
Old 12-02-2010, 11:55 AM
Talyn's Avatar
Talyn
Talyn is offline
Yeah, somebody on here has a thing about doing that.
No idea who posted it though.
Old 12-02-2010, 12:40 PM
Hussler's Avatar
Hussler
Hussler is offline
I've never tried it but don't think it would work. If it was me I would unplug the IAT (intake air temp) sensor and stick a 37K ohm resistor across the two wires. PCM will think air temp is about 68 degrees and should not activate the EBPV except on engine start up diagnostic. IAT sensor is only used to control the EBPV (cold mornings) and has no other effect on engine fueling or performance.
Old 12-03-2010, 12:29 AM
mongo12's Avatar
mongo12
mongo12 is offline
ok that makes sense for the iat to work the ebpv, i thought i read somewhere that the oil temp sensor also contributed to the valve's operation, good call i will look into that.
