Mobil 1 synthetic oil change intervals
Guess you didn't believe us, huh?
Ford F150 - Mobil 1 synthetic oil change intervals - Ford F150 .net
I guess he was hoping for us to say 10,000 miles?
Personally, I'm going to be changing my synthetic somewhere between 5&6k. My driving is 90% city, stop and go, short trips right now and although it's more costly, etc etc, I feel better about it.
It's actually going in to the shop in about 1.5 hours for its first full checkup since I've had it. (Oil change, check the fluids in diffs, trans, transfer case, rotate balance)
What facts do you have to support this? Have you done more testing than the manufacturer? 'Cause they warrant these engines to 60,000 miles, and have a lot to loose if their maintenance schedule causes engine damage.
Is there something I'm not seeing here?
Synthetics will go longer than 7500 miles given normal conditions. I would think the filter is the limiting reagent in the equation. Its a paper filter afterall. I've been using Pennzoil Platinum for a couple years and I change around 7500 miles because I fear the filter.
These pics are from a FL-820S with 3000 miles on it...looks pretty good (got these from bobstheoilguy website).
I run Mobil1 synthetic and I change it every 10K miles and I change filters every 5K. So, my oil change kit includes 8 qts of oil and two filters. 6 qts of oil for the initial change, 1 qt to make up for the loss during filter change and a spare qt.
Now, the engines on the 2011 F-150's are all set up for 10,000 miles oil change intervals as per Ford Motor Company. Granted, these engines all have 8 qt sumps but that's 10K on one filter.
msm718
1997-2006 Expedition & Navigator
02-17-2004 03:58 PM
91Bronco
06-08-2001 10:33 AM
