Air Compressor for Suspension
air compressor isolators
Note: Expy RR instructions.
Before you go a buy a new unit, remove the battery and battery case, then remove the bolts holding the windshield washer fluid (and 2 electrical connectors) and the electrical connector at the AC line near the front (optional). At this point, you will have clear access to the pump. Do not remove the lines at this time. Grab the unit and see if it wobbles pretty freely. If it does just order a set of isolators (see link below). When you get them you can install them without removing the unit, just remove the screws and turn the unit on it's side being careful not to damage the airlines. You will need a torx screw driver (t-20) to remove the the isolators. Again, you don't need to remove the airline or the unit to change the isolators. As far the time to RR - it took me about 30 minutes (if that), but I've done it a couple times before, so it's easier now. Now get busy.
New Vibration Isolator Kit for 1997-2002 (4 wheel drive) Expedition
BAD RONALD
1997-2006 Expedition & Navigator
21
10-25-2017 08:45 PM
qwertypert
12-07-2016 07:25 AM
BlackTruckPL
04-25-2016 02:21 PM
BlackTruckPL
04-23-2016 03:19 PM
