What should battery voltage be? - Ford Truck Enthusiasts Forums
Old 12-01-2010, 02:10 PM
mblanken881 mblanken881 is offline
mblanken881 is starting off with a positive reputation.
I am getting the following using ScangaugeII:
Voltage w/ keyoff: 12.5
Voltage w/ key on after glow plug light turns off: 10.9-11.1
Voltage after about 30 sec of running: 13.9-14.0
I'm a little worried about 10.9-11.1. Seems low. Think my batteries are shot?
Old 12-01-2010, 02:21 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
My post glow plug is a little higher but still in the ball park.
Old 12-01-2010, 03:47 PM
jasontrucks76's Avatar
jasontrucks76 jasontrucks76 is offline
jasontrucks76 is starting off with a positive reputation.
Sounds perfectly normal to me... The alternator does not kick in the instant you start the truck either. I know this from checking alternator amp draw repeatedly the other night.
Old 12-01-2010, 05:39 PM
Alright thanks. Good news
Old 12-01-2010, 07:46 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Quote:
Sounds good.
Sounds a bit low. I've never seen mine drop into the 10's. Your reserve amps might be on the low side. How old are these batts? Not the originals, I hope. Right here is where your FICM is most vulnerable, with glow plugs on, voltage low, and you hit the starter. I would get those batts load tested.
Your alternator is working good.
Old 12-01-2010, 08:20 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Check fluid level in the battery (s). 12.5 is starting to get low too....Mine (fairly new) is running 12.7 -no load. Agreed - the alternator is doing it's job.
Maybe get it (them) load-tested.
Old 12-01-2010, 08:27 PM
jetpilot1's Avatar
jetpilot1 jetpilot1 is offline
jetpilot1 is starting off with a positive reputation.
That sounds good to me, I believe just because the glowplug light is off, it doesn't mean the glowplugs are off, so you still have a 180 amp draw till they turn off.
Old 12-02-2010, 12:52 AM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
Check out post 10 on the following link
http://www.ford-trucks.com/forums/88...-bad-ficm.html
Old 12-02-2010, 02:04 PM
DSMMH's Avatar
DSMMH DSMMH is offline
DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.
Quote:
So are you saying the alternator is OFF the first 20 to 30 seconds the motor is running?
You disconnected the alternator output and ran it through a ampmeter to verify no alternator output?
If true, I'll have to get my electrical diagram out and see how Ford cuts off the alternator. I assume they interrupt the exciter field voltage.
DSMMH
Old 12-02-2010, 02:09 PM
bpounds's Avatar
2 bit Californian
Quote:
It is true. You can clearly see it on a gauge. I don't know how it is done.
Old 12-02-2010, 02:14 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
This is a question I had for a long time and I finally tested it with a clamp ammeter.
The voltage regulator in the alternator is turned on by the I circuit. In a single alternator setup, that circuit goes to the instrument cluster and is part of what controls the battery warning light.
The instrument cluster does not apply voltage to the I circuit, thus not turning on the alternator, until the glow plugs have shut off.
The test I did was to put the clamp ammeter on the B+ wire coming out of the alternator. I then started the truck cold and observed little voltage (less than 5 volts) for about 90 seconds. Then I observed it go up to about 90 amps.
Old 12-02-2010, 02:18 PM
Here is the single alternator wiring diagram.
Old 12-02-2010, 02:38 PM
DSMMH's Avatar
Thanks for the info. I'll have to do a little research to totally understand this. i hate partial mysteries.
DSMMH
Old 12-02-2010, 05:20 PM
Thanks for jumping in there guys!
I had to work today :0(
I noticed this when I replaced my alternator a couple days ago and had to dig in to it a little to figure out why also. Not sure I still know WHY Ford does it this was but i now know what i am seeing is correct.
Gould it be that the GP's draw more then the single alternator can handle so they just decided to keep the alternator off until they cycle off?
Old 12-02-2010, 05:24 PM
I've wondered why they do it too. The only thing I can figure is that the very high current draw of the glow plugs might cause damage to the alternator over time.
Glow plug related stuff . . . again! 1'stonraceday 1999 - 2003 7.3L Power Stroke Diesel 10 03-28-2014 08:07 AM
Batteries brandon.edwards 6.0L Power Stroke Diesel 4 01-07-2014 09:34 PM
Battery and Alternator Voltage before I buy new batteries 99StrokeXLT 1999 - 2003 7.3L Power Stroke Diesel 5 04-04-2013 06:51 AM
Battery Not Charging schuster66 Escape & Escape Hybrid 6 04-22-2012 11:57 PM
Cold crank volts for 7.3 dyhrdford 1999 to 2016 Super Duty 13 12-04-2009 06:03 PM
Tags
122, 13, 2003, 60, batter, battery, diesel, engine, f250, f350, lincoln, mark, start, truck, viii, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
