Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-01-2003, 10:34 PM
goodbread is starting off with a positive reputation.
Oil pressure gauge is really an idiot light?
A couple of years ago Popular Mechanics fielded a question from a reader in their auto mechanic column. The gist of the letter was that Ford installed a constant voltage sending unit in late model Rangers (and probably other vehicles) so that once any oil pressure was sensed on engine start the gauge read a normal center-of-dial reading. You can see this on start up if you watch how the gauge works. The needle will jump the moment the engine fires to this "normal" position. A true oil pressure gauge would increase its pressure at something other than an instantaneous rate. The editors went on to say that a variable resistance sending unit would probably make the gauge act like we expect it to.
I'm new to the forum. Has anyone heard of this and confirmed it? Has anyone researched and found a sending unit that will make the gauge act like it should?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-02-2003, 08:53 AM
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
First, welcome to FTE!!!!!
You are exactly right, the oil pressure gauge on Rangers (and
ther Fords) is an idiot light! The oil pressure sending unit is a
"normally open" switch, that closes with about 7PSI of oil
pressure. When the "switch" closes, the current through the
oil pressure gauge is set by a 20 ohm resistor, mounted on the
back of the instrument panel. This current makes the gauge read
at "half scale", and will not show changes in oil pressure.
You can change the sending unit to an "analog" type of sending
unit, and "short" the 20 ohm resistor, to convert it to a real oil
pressure gauge. I will say, that when I converted my 1999 3.0L
FFV, I DID NOT have the 20 ohm resistor in the back on my
instrument panel, so just ended up changing the sending unit..
Good luck!!!!
  #3 (permalink)
Old 03-03-2003, 09:54 AM
WXboy's Avatar
WXboy is starting off with a positive reputation.
This is a very good question...and one that I am looking into myself. Bob has offered me advice on this issue too, and I am getting ready to attempt to fix it using his method. He told me a sending unit from a late 80s model Ranger will work if you change the connector on it. I hope it works!
WHY did Ford even bother with a "dummy" gage? They should either use true pressure gages like GM, or not use one at all like Toyota. Shame on you Ford!
If anyone else has any info. on what model years units will work, please post here. If the '90 model 4.0 sending unit would be "analog", I think that would be an easier swap.
__________________
2003 Ford Ranger S/C FX4
  #4 (permalink)
Old 03-03-2003, 02:16 PM
Charnsen is starting off with a positive reputation.
What year of Rangers' are we talking about here? I'm curious to know if mine is a 'dummy' guage or not... '92 4.0L 4x4. I do a lot of highway driving (truck is used for work) and would like to make sure I'm getting a real indication of oil pressure.
  #5 (permalink)
Old 03-03-2003, 03:51 PM
WXboy's Avatar
From what I have read, all Ford trucks 1986 and newer probably have "dummy" oil pressure gages that jump to a default center-of-dial position when the engine is started, rather than actually measuring fluctuations in pressure.
The only way to fix it is to install an analog "variable resistance" oil pressure sending unit. Problem is, I don't know which model years were equipped with these, and I don't know if they would be a direct swap or not.
__________________
  #6 (permalink)
Old 03-04-2003, 08:55 PM
Sorry, I didn't list my model year. I have 99 XLT 4dr SuperCab, 4X2, 3L V6, Auto
  #7 (permalink)
Old 03-11-2003, 10:35 PM
Gcoldtruck is starting off with a positive reputation.
Re: Charnsen
Your gauge is a dummy guage. Ihave a '92 4.0 2wd and my guage is always solid in the middle.
  #8 (permalink)
Old 03-12-2003, 05:48 PM
JEY JEY is offline
JEY is starting off with a positive reputation.
What year Ranger (early 80's,...??????) has the sending unit to convert the oil pressure gauge? I have an 01 model with a 3.0 engine. I would like to convert also.
Thanks, JEY
__________________
JEY
  #9 (permalink)
Old 03-12-2003, 06:18 PM
Rockledge's Avatar
Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.Rockledge has a great reputation on FTE.
JEY, if you read through this recent thread from the Oil Forum you'll find the answer to your question
http://www.ford-trucks.com/forums/sh...hreadid=102134
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #10 (permalink)
Old 03-14-2003, 07:57 PM
GotBeer? is starting off with a positive reputation.
Sounds like something I might like to try on my '02, but I have to wonder what this would do to the warranty?
  #11 (permalink)
Old 03-17-2003, 08:09 AM
1991rangerford is starting off with a positive reputation.
i have a 1991 4.0 auto, my oil pressure gauge works as it should, doesn't stay near the center.
I notice i don't carry anywhere near the center of the guage for pressure but maybe its not working right )
__________________
03 Black SXT
Chill factory stage 2 turbo-275hp, nuff said
2001 Ranger XLT 2wd 2.3 5 speed
Stock, and staying that way
1991 Ford Ranger 4.0 Short Bed 4" lift 235-75s-sold!
  #12 (permalink)
Old 03-17-2003, 08:37 AM
If it is working as a gauge, you will see fluctuations in the needle.
When cold, it will read higher, but when hot, and idling, it should
read lower......If the needle stays in the same place, then you
have an "idiot light" type of gauge....
  #13 (permalink)
Old 03-28-2003, 08:11 PM
PT17Pilot's Avatar
PT17Pilot is starting off with a positive reputation.
Hello all, new member here. On the oil pressure gauge thing, I turned mine on my 93 Explorer into a normal gauge. Here's how it worked on my Explorer. Pressure switch turns on if pressure is above 5 lbs I think. This would make the gauge go full deflection, high. They wired in a resistor before it gets to the gauge and that's what brings the needle down to around half and it stays there. I installed a 0-80psi sending unit , removed the resistor from the back of the gauge and ran a jumper wire across it. And now have a working gauge. I just bought a 1995 Ranger, and am assuming it will be the same way, I will tear into it and probably do the same thing to it.
CJ
  #14 (permalink)
Old 03-28-2003, 09:33 PM
Thanks for the good replies. I looked for my sending unit where Rogue Performance said it was, behind the right cylinder head and I couldn't find it. At Rogue's website there is a good photo showing the sending unti from behind the engine with the transmission removed. Do you have to remove the tranny to see it? I've change them before and this one looks what I remember, but I can't seem to find mine? Do I just need better glasses?
  #15 (permalink)
Old 03-29-2003, 07:49 PM
That picture of for 1 3.0L, do you have a 3.0L? The sending unit
is in a different place on the 4.0L.....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
