ken no matter what the trucks alignment is getting checked and if it is out even just a small bit I will have it done. but if it is still within spec I wont have it done.
Howdy Big D...a couple hundred for an oil change seems rather high...I think our diesel oil changes are about $130+/-.
evening Ken
Not just the oil change Ken..
Had them check on the hard starting and blowing smoke in the morning.. They found the FICM voltage was low.. There is a TSB on the subject so I am sure I will be jabbed the $100 deductible on the warranty work..
Hopefully this fixes the problem I have been complaining about since new..
I would think that if there is a TSB...there shouldn't be a deductible. I have a 2011 F350 Crew Cab King Ranch that will definitely solve your problems!!!
I am sure it will Ken..
Just put a bow on it and have it here for Christmas..
