You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 1993 Make: Ford Model: F-350 Price: $4800 Mileage: 76000 Color: red Private or Dealer Listing: Private Listing Location (State): NY Transmission: Automatic Drivetrain: 4WD & AWD Color: Red Engine: 7.3l N/A
1993, f350, 76k original miles, 7.3l diesel motor e4od automatic trans, 4x4 dana 60 front sterling 10.25 rear $4800 located in upstate ny
new gastanks, new differential cover, steering gear box, new international CDR valve, new driver hub, headlight switch, radiator, thermostat, new brakes and calipers&rear shoes, all 6 tires new, new driveshaft u joints, new inner and outer tie rod ends, new steering stabilizer, serpentine belt,a/c idler pulley,tensioner pulleys,belt tensioner, 8 new BB code injectors with return line kit, new injection pump, brand new seat,transmission mount ,output shaft seal, truck has a omaha standard flatbed, 9.6 foot long 8 foot wide, pintle mount plate, fresh alignment and wheel balancing, fuel lines and rear brake lines,electric fuel pump, 1.5" leveling kit in front
