4r100 or 4r70w - Ford Truck Enthusiasts Forums
4r100 or 4r70w
Old 11-30-2010, 12:39 PM
chicagodragon's Avatar
chicagodragon chicagodragon is offline
chicagodragon has a very good reputation on FTE.chicagodragon has a very good reputation on FTE.chicagodragon has a very good reputation on FTE.
4r100 or 4r70w
will one of these work where the other was? is it just a bolt up, or? i need to replace my tranny and i see both for sale on craigs list. its raining now, so iam not going to crawl under my truck to count pan bolts. anyway, i have a 1999 f150. are they the same bolt pattern from 4.6l and 5.4l? thanks
Old 11-30-2010, 05:12 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
No. E4OD and 4R70W are totally different. E4OD is based on a C6 and 4R70W on an AOD
Old 11-30-2010, 05:57 PM
i meant 4r100 compared to 4r70w
Old 11-30-2010, 08:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
No, you can't just bolt one in where the other used to be. The bolt pattern to the engine is the same between a 4.6L and 5.4L, but everything else is different. The length is different. The hardest part to overcome is that the wiring is different and the computers are different.
Old 11-30-2010, 08:36 PM
Thanks, That's What I was looking for.
Old 12-01-2010, 04:38 PM
i ended up getting a used 4r70w (thats what i had) what can i check out befor i install it to see that it will work? anything? or am i taking a gamble?
Old 12-01-2010, 08:11 PM
You could take it to a trans shop that has a transmission dyno. Not many do, but there are a few. It won't be free to test it, but it can be done.
Your other option is to tear it down and rebuild it. Most people just install a used one. Usually they work.
Old 12-01-2010, 09:09 PM
Are these hard to rebuild? I've done c6's before, but nothing electronic. I was going to try to fix the old one. No reverse and slipping in toward. Just happened all of a sudden with no warning. Btw, reps sent
Old 12-02-2010, 04:52 AM
They are a bit more complicated than a C6. You'll need a GOOD manual. ATSG or Helm, Inc, have good manuals.
Old 12-02-2010, 05:10 PM
any special tools needed? do i just replace the clutch discs or..... any info would be great. best place to get a kit?
5R110 Help islandboy007 1999 to 2016 Super Duty 8 08-03-2014 09:52 AM
Swap 5.4l with v10 Cajundawgs 1999 to 2016 Super Duty 6 10-26-2012 08:17 PM
Transmissions!! Difference between an 4R100 Gas and Diesel?? 4wheelingpete 1999 to 2016 Super Duty 2 06-22-2012 04:44 PM
5.4l to 400 (335 series) 4r100 bolt up? nogo73 Engine Swaps 14 05-20-2011 12:48 AM
4R100 trans bolt up question, 5.4L, V10, diesel. PPrash 1999 to 2016 Super Duty 3 12-06-2009 10:46 AM
Tags
4r100, 4r70w, auto, clutch, covert, expedition, ford, homemade, reverse, sudden, to4r70w, tool, trans, transmission, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
