Noisy Brakes
Noisy Brakes
The front brakes on my 97 4x4 are squealing and I've -
changed the pads and rotors
inspected the caliper pins
tried grease and no grease on the pins and slides
changed the pads again
I used Permatex brake quiet on both sets of pads... one guy suggested removing that. I find it hard to believe that a company as reputable as Permatex would put out an inferior product but I tried to remove as much as possible today... still squealing.
A search on this forum only produced a couple of suggestions... washing more frequently and trying a different brand of pads. Any other suggestions?
Tom
Tom
Noisy Brakes
You can try sanding down the pads and rotors to remove any glaze on them......while wearing a dust mask of course
You can also try chamferring the ends of the pads with a file.....while wearing a dust mask of course
That may help for a while but usually you have to change the pads to cure it. Sometimes cheaper (softer) pads are quieter although they might not last as long as better ones.
I dont like using any anti-squeel stuff on the pads. It might seem to help for a while but then it seems to make it worse.
What kind of grease did you use on the slides and pads?
Ford recommends their dielectric /caliper slide grease.
Noisy Brakes
Originally posted by Racerguy
You can try sanding down the pads and rotors to remove any glaze on them......while wearing a dust mask of course :)
You can also try chamferring the ends of the pads with a file.....while wearing a dust mask of course :)
I dont like using any anti-squeel stuff on the pads. It might seem to help for a while but then it seems to make it worse.]
Noisy Brakes
I had the squeeking problem on one of my trucks. I checked everything. The pads were thick, and everything else looked good, so I asked a local tire shop guy. He told me to go out and get it up to about 45mph, then lock up the brakes. Apparently this gets rid of the shiny finish. I did it, and no more squeek.
Noisy Brakes
What kind of pads are you using? Usually the el cheapo ones make some sort of noise. I've had good luck with the Pep Boys midrange pads and the high end raybestos quiet stops.
I've got this brake squeal stuff from Pep Boys - it's great. It comes in a little red bottle - the stuff is the consistency of toothpaste. I cover the back of the pads with it, then put on the backings, then cover the backings with it. No noise whatsoever - since the stuff is kinda rubbery, there's no way the pads can vibrate.
XXL
XXL
Noisy Brakes
Well it's been about three weeks now... I think it's safe to say that it's fixed. I switched from AutoZone's entry level pad to the next level up and didn't put -anything- on them. So far so good. No way to tell now if it was the brake quiet or the pad material but I'm betting it was the pads.
Tom
Tom
Noisy Brakes
Originally posted by tw
Dry dusty conditions make my wifes expy squeal the breaks, even with the premium bendix pads. One good hard brake takes care of it for a while. Or one good rain, but those are hard to come by any more.:-X04
Tony Warren
Nebraska
Tony Warren
Nebraska
I've heard that from several other people but I believe ours was more severe. I could wash out the brake area real good, and it might not squeal the first stop. Also tried the 'hard stop' approach to knock off the glaze. That never seemed to help at all.
With the new pads, no noise anytime (so far!).
Noisy Brakes
I had it looked at by both the used car dealer I bought the vehicle from (they put new front brake pads on before I bought it) and a local tire shop. Tire shop did an "anti-squeak" fix on them, but it didn't last very long, about two weeks. They said the pads look quite new and in good shape. I'm guessing the dealer used a cheap pad material. I've heard about using ceramic pads, but don't know much about them. So I'm looking to use the same one's you ended up with, if they are still working fine.
Noisy Brakes
Back in the Fall of '97 I replaced the perfectly good stock pads on my Expy for better performance in competition and other severe use under extreme conditions, with Porterfield Brake's Kevlar/carbon brake pads, Model R4S (see www.porterfieldbrakes.com).
I get about 50 to 60K miles from them front, and 80-90K miles rear. They never have squealed or had a dust problem. I've never had to turn the rotors or make other adjustments at all, even though I drive 2-3K miles per year off the pavement in gravel and sand. I now have 112K miles on these pads and can't imagine anyting better in cold or hot, wet or dry, red hot rotor race conditions or just idling around town. The brake feel is always the same, regardless. They have not faded on steep downhills wiht heavy loads. They are worth every penny. $89 front pair, $79 rear.
Like when I choose tires, I want the best in brakes, not what's on sale or popular.
Hope this helps.
Hope this helps.
Noisy Brakes
tsdrallyer,
I tried your link, no go. But this one worked
http://www.porterfield-brakes.com
My pads are fine, but they squeal, I will check out Porterfield brakes.
jcmac
11-12-2001 07:24 PM
