Bronco will not start after rain - Ford Truck Enthusiasts Forums
Old 11-30-2010, 10:03 AM
h2oline h2oline is offline
h2oline is starting off with a positive reputation.
I have a 1996 Bronco that will not start after rain or heavy snow but will start if the weather has been dry even in very low temps. I have had the plugs and wiring replaced, it has a new rotor, etc. It is so regular and consistant with the no start issue I could bet on it. I've had it hauled to the garage only to have it start once it got there....any ideas?
Old 11-30-2010, 10:28 AM
rotor vs. coil
meant coil...not rotor....duh!
Old 11-30-2010, 10:30 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
grounding issue. Could be distributor related. Suggest rebuild distributor.
Old 11-30-2010, 12:02 PM
The distributor was rebuilt 2 years ago while we were trying to figure this out. It still has the same problem...
In the last few minutes I spoke to a neighbor who has an F-350 truck. He mentioned checking the PCM for water?? Where would I find it on the Bronco. He said they can be in different places on each vehicle. Wouldn't a problem like that cause it not to start ever (after it got wet)?
Old 11-30-2010, 09:01 PM
Driver's side kick panel, rain might be getting in thru the gasket.
Old 11-30-2010, 11:22 PM
cOpE!'s Avatar
cOpE! cOpE! is offline
cOpE! is starting off with a positive reputation.
Next time its wet out, try spraying the dist with WD40 then try to start. Next time try spraying the PCM then start. Do those new fangled broncos have the old Ignition control moduals? try that too. WD should dry it up and give you an idea of where your issue is.
Old 12-02-2010, 06:33 PM
SpeedyReid SpeedyReid is offline
SpeedyReid is starting off with a positive reputation.
if the distributor is getting moisture in it it will not spark, the dw-40 absorbs the moisture and it should start up if thats the problem, they sell distributor boots for the distributor.
i had this problem on my 1970 c-10 mud truck.
just a suggestion, try it it might work.
let me know how it goes, good luck.
Old 12-02-2010, 06:57 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Check the resistance of the battery cables. Corrosion doesn't only form on the terminals and at connections. Resistance should be less than 5 ohms. Make certain you disconnect the cables before taking a resistance reading. Moisture compounds the issue if resistance due to corrosion is the problem. So humid weather would qualify.
1994 Bronco will not start in Rain or Snow shartma2 1978 - 1996 Big Bronco 6 01-26-2014 09:17 AM
E-150 5.8L wont start after hard rains Biggggbarney Ranchero & 1961 - 1967 Econoline 0 07-20-2011 10:58 AM
Wont start in the rain pickupman96 1999 to 2016 Super Duty 2 03-11-2011 02:42 AM
engine stumbles when humid or raining nlfireblade 2004 - 2008 F150 15 01-25-2010 01:35 PM
crack in rain gutter traderguy111 1978 - 1996 Big Bronco 5 09-18-2004 08:11 AM
Tags
150, 1986, 1994, 1996, assembly, brake, bronco, distributor, doesnt, f150, ford, rain, raining, start, starting, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
