Taking Apart A Center Console - Ford Truck Enthusiasts Forums
Old 11-30-2010, 08:23 AM
curt9999 curt9999 is offline
curt9999 is starting off with a positive reputation.
I want to install a couple of 12 volt outlets in the rear of the center console. I have installed one, but it is only held in by a couple screws into the plastic shell of the console.........would like to use small screws and nuts instead....... need to get the console apart to do this...... Any ideas
Old 11-30-2010, 10:20 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
It's a little pricey for the tool, but riv-nuts would take care of some the problem.
What vehicle is this in?
Old 12-01-2010, 07:14 AM
RE center console rivnuts
This is for a 2006 F250. I canot get my hand between the outside shell and the inside of the center console to hold a nut. I thought there might be a way to take the center console apart.
Old 12-01-2010, 06:27 PM
ReAX's Avatar
You don't have to use machine nuts. Since it will be next to a hole, a cheaper option than riv-nuts would be speed nuts(also called, Easy nuts, e nuts, clip nuts, ect). They are the sheet metal clips with the holes in them.
If you must use standard nuts, you might have some luck getting to the location from underneath. Unbolt the console from the floor and take a look.
Old 12-02-2010, 12:35 PM
2010PLATINUM's Avatar
2010PLATINUM 2010PLATINUM is offline
2010PLATINUM is starting off with a positive reputation.
some
good videos on taking stuff apart on this site
FORD LOCKPICKS
Center console Broncoguy89 1999 to 2016 Super Duty 2 08-15-2014 10:23 PM
2008-10 Center Console in 2011 40 oz 1999 to 2016 Super Duty 2 10-28-2012 09:54 PM
Overhead console removel LRoshau 2004 - 2008 F150 0 01-14-2005 05:15 PM
Explorer XLT '03 Center console removal MrWiggly Explorer, Sport Trac, Mountaineer & Aviator 1 03-07-2004 12:20 AM
Center console removal ? beemer 1997-2006 Expedition & Navigator 4 06-17-2002 01:35 PM
Tags
04, 2003, 2007, 2008, aparty, center, console, dudy, expedition, f150, f350, ford, lightning, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
