You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I've got a 1980 ford Courier made in Japan by Toyo Kogyo. It has a 2.3L I4. Is this the same engine used in the Ranger or is this a Jap built engine? RB
__________________
Check out my webshots page.
75 Ford Bronco 5.8L EFI,NP435,D20 on 35" MTR's
96 E350 24 passenger bus 7.5L
93 Ford Broncostar 4.0L NP435 BW1356 (Avatar)
95 F250 4x4 351, E4OD, 1356
98 Ranger 3.0L
It's the Ford engine. Couriers with the 2.3 are Ford engines, the 2000 and 2600 are Mazda engines.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Look on the emissions sticker under the hood. The displacement should be listed near the bottom of the sticker
If that is missing or has been painted over, look at the dist. Does it come out of the head near the front of the engine, or stick out the side of the block part way back?
Dist in the head = Mazda 2.0L (wide cast aluminum valve cover)
Dist in side of block = Ford 2.3L (narrow stamped steel valve cover)
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
Hello, thanks very much, the sticker with the dislpacement still there and yes, the Valve cover is the stamped stheel, so it's a 2.3 Ford Engine, that's really what I want to have.
Thanks very much for the help.
I got the spark plugs, whires, and air filter plus the front shocks to be installed today. will place some pictures later.
