brake line advice
brake line advice
Started off by replacing the brake pads and hoses to the calipers, but on removing one of the hoses, the hard line was rusted to the connector. I went to the store to get new hard line, but the parts counter guy sold me a compression fitting. Got the truck back together but had reservations about compression fittings on brakes. After reading online, I'm correct about my reservations. What should I do now? I could either replace the whole line or get a union and flare tool to make a stronger joint. Also, what is the size and thread of the current flare joints?
thanks
thanks
Don't use compression fittings on brake lines. In fact, the one time I bought a compression fitting the counterman made sure I wasn't going to use it on a brake line. I was under the impression they were NOT to recommend them for use on brake lines.
If you need to replace a section of brake line, using a union and a good flaring tool would be the correct way to do it, or you could replace the whole length. If you need to make any bends, a cheap bender would be very helpful also
This is the first time that I did hard line brake work and the counter guy gave me the compression fitting! I drove the truck last night to test brakes, but after my reading about compression fittings, the truck isn't moving until I get it right... I had good luck bending line with various round objects found in the garage, but will get the correct union and flare lines tomorrow.
Note that the flaring tool is a special one just for brake lines, not to be confused with a flaring tool for plumbing. The automotive type has a special cup to roll the tubing inward before flaring outward. This makes a very strong joint, which you absolutely need. I picked up a good used flaring tool on ebay. DO NOT use compression fittings!
Picked up the parts tonight, thanks for the advice. Got a union, and flare tool with nuts. I already had a 10" length of tube. When I walked in to the store to ask for the union, the guy tried to talk me out of it and into a compression fitting, he even had one labeled "brake compression fitting". He also said that most people who come in with my problem buy those, maybe I should not drive on busy streets here... Also went ahead and bought the flare tool since it was only $20 and it'll be in my tool box for next time. I'm one to spend a little money when it comes to brakes and grabbed a new set of calipers since I'll be bleeding the lines again anyway, I don't want to cheap out on brakes on the vehicle that hauls lots of weight.
