Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
85 ranger tough truck
Old 11-25-2010, 09:20 AM
4x4chevette's Avatar
4x4chevette
4x4chevette is offline
My cousin has ran this ugly pile for 5 years at tough truck events around ohio. I have also been running for 5 years but this season (2010) I didnt have a vehicle to run. Last year he built a Jeep and I got this for next to nothing. Was once an 88 Ranger 2wd 2.3 5 speed
After I ran it at 5 events I managed to roll it comming around a corner.
It looked like this
I jacked the corner up enough to make my second run, and here it was upon unloading from the trailer
I stripped it down and pulled the "good parts"
I picked this up for $100. 85 2.8 auto 4x4.
I compltely stripped it to the frame, leaving only the axles.
The 2.8 was locked up so Im using the 2.3 and 2wd trans from the rolled ranger with a divorced nissan 720 pickup transfercase. Engine is sitting 4" back
Fuel tank is inside the tool box. Tanks is mounted down with 3 straps going over it and through 1/4" steel plate with six 1/2" bolts.
Toolbox lid is bolted down with four half inch bolts, the factory latches, and a padlock and key.
Currently have four half inch bolts going through the 1/4" plate to the frame, putting 4 more in after I go buy them.
Total wieght with full tank of fuel is about 300 pounds. I also have the ability to ad sand bags inside the toolbox for more wieght if needed. ( to keep it from nose diving on jumps)
Cab is sitting 6" back and the front is cut and bobbed. Doors, fenders and hood are skins only, total combo probably wieghts less than 200 pounds.
Going to order a jegster 12point cage for it and I need to do some finishing touches to the body before paint but here is a really bad attemtp at using windows paint to finish it
Old 11-26-2010, 02:32 AM
panman65's Avatar
panman65
panman65 is offline
good luck hope ya win
Old 12-05-2010, 07:10 PM
4x4chevette
This is a prebent cage from jegs so it doesnt fit quite like I wish it would.
Front mount, Im going to be bolting the flat plate to the channel so that I can remove cage and cab.
The channel is set down over top of the factory cab mount.
Rear mounts. There is a solid piece fo 4" 1/4" thick channel that the cage is welded to, the channel will be bolted to these mounts. Thes emounts are 1/2" plate welded tot he stock body mount location with a 1/4" thick gusset welded on.
Rear loop and the halo. Cage is welded to the cab everywhere it come incontact with it.
one of the a pillar supports
Got alot more left to add but I should have it done in the next couple days
Old 12-06-2010, 05:28 PM
4x4chevette
Old 12-07-2010, 08:09 PM
4x4chevette
Rear channel cross member
rear downward supports
other a pillar support
close up of the front frame mount welded to frame
Bent the door bar JEGS sent so that I have soem elbow room
Old 12-09-2010, 09:03 AM
4x4chevette
One of the front bars
Seat mounts
Some more of the interior tubing, still got alot to add
Thought this was neat. Running on one spark plug. ( was trying to find a slight misfire)
Old 12-09-2010, 11:30 PM
4x4chevette
Old 12-10-2010, 08:19 AM
COMPLIT1107's Avatar
COMPLIT1107
COMPLIT1107 is offline
Great looking job ! and nice welding skills. (Some of us only use our welder to provide practice time with our grinders )
Old 12-12-2010, 03:48 PM
4x4chevette
Old 12-17-2010, 06:21 PM
4x4chevette
dazedandconfused
109
02-23-2021 03:44 PM
bruggeri
17
04-02-2014 01:04 PM
mmollo
6.7L Power Stroke Diesel
28
02-24-2013 08:02 PM
TulloFord
02-14-2013 05:26 PM
ArrizX
Offroad & 4x4
244
09-05-2012 09:20 PM
Quick Reply: 85 ranger tough truck
