Here's why we shouldn't be using more than B5 fuel...
Fuel dilution of oil is the problem not bio! I would say trucks with a lot on idle time, in town driving, has this problem more than bio. I have run 99% 50% 20% sent truck was new. My Truck has never made oil, ( change 3,000 - 3,500 miles ) very little in town driving, trips are 40/50 miles at time, no idle. The biggest problem with bio is bad made product!
It mentions how bio is more likely to wash the cylinder walls and make it past the rings due to it's composition, and that tests have shown that the percentage of bio making it into the crankcase is WAY higher than the percentage of bio in the fuel.
Also note this in the 6.7L diesel supplement, which happens to be certified to run B20.:
Originally Posted by 2011 6.7L diesel supplement
5W-40 or 15W-40 oil is recommended for fuels with greater than 5%
biodiesel (B5).
biodiesel (B5).
There is a LOT of good science there, it's very tough to argue with!
I personally shy away from the stuff. Less energy and cost the same or more. Economically that does not make sense to me.
I once tracked a tank of that stuff. Running empty accross IL of course. Got around 11 mpg's if I recall. Every other tank was in the 14's.
Granted that was when the truck was new. As I now can routinely get in the 16's.
