High Idle Mod 2007???? - Ford Truck Enthusiasts Forums
Old 11-29-2010, 05:09 PM
Mlitt12345's Avatar
Mlitt12345 Mlitt12345 is offline
Mlitt12345 is starting off with a positive reputation.
Can i do the high idle mod on my 2007 6.0L? Could only find yrs 2003-06 in tech folder. Thanks, Mike
Old 11-29-2010, 05:16 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.
Should be pretty close to the 2006 version.
Old 11-29-2010, 05:22 PM
lawnboy1965's Avatar
lawnboy1965 lawnboy1965 is offline
lawnboy1965 is starting off with a positive reputation.
I have the orange wire and plan on doing it tonight. I am picking up the fuse blade adaptor (so I dont have to wrap the wire around the fuse) at the parts store on the way home.
Old 11-29-2010, 07:54 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
same as an 06
Old 11-29-2010, 08:08 PM
Mlitt12345's Avatar
Confirmed.......works same as 2006, just did my 1st mod and man was it easy...the high idle mod works great...used 2 butt connectors and about 8" piece of wire to make it easier to install...Thanks for the replies, Mike
Old 11-29-2010, 08:11 PM
SFC-REMF's Avatar
SFC-REMF SFC-REMF is offline
SFC-REMF is starting off with a positive reputation.
Now if I can just find the d@mn orange wire on my 04.
Old 11-29-2010, 08:43 PM
roadrunner01 roadrunner01 is offline
roadrunner01 is gaining momentum as a positive member of FTE.roadrunner01 is gaining momentum as a positive member of FTE.
when i did my 07 i just hooked the two wires together and high-idle is activated by depressing the e-brake. i don't have the upfitter switches and didn't see the need to add a switch. whenever i want the high-idle i just depress e-brake and trans in park
Old 11-29-2010, 08:53 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Quote:
I don't think the 04's have the orange wire. The "orange" PTO was added in 05 from what I understand. I might be wrong, but the directions for the 03-04 doesn't mention it.
Old 11-29-2010, 10:02 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
2003 and 2004 are different from later years. These are instructions.
High Idle Mod
Old 11-30-2010, 12:00 AM
SFC-REMF's Avatar
I read those instructions, I was trying to do it without a switch and just use the e-break like Serapis did here http://www.ford-trucks.com/forums/1007950-high-idle-mod-a.html.
So I wonder if I take wire 322 and wire 294 and just splice them together with no switch? It should put it into high idle mode until I hit the break correct?
Old 11-30-2010, 05:34 AM
Yes, if you just wired them together, it would be ready for activation every time the truck is in park and running. Now, would constantly being in activation mode hurt anything, I don't know. Would I want to try? Not me.
Old 11-30-2010, 09:17 AM
Quote:
Roadrunner, What two wires? I just ran mine to the fuse box with a 10a fuse in an unused spot.
Old 11-30-2010, 10:04 AM
jfletcher72's Avatar
jfletcher72 jfletcher72 is offline
jfletcher72 is starting off with a positive reputation.
not working for me....
I have an 05...I found what i think is the correct "orange" wire...that was in a bundle behind the Ebrake. I spliced on a piece of wire and ran it to my fuse box. I used the 20a radio fuse. I was not able to get the high idle to engage. Truck was in park, and Ebrake was on. What am I missing? Is there another orange wire I should be looking for? This one was in a bundle of probably a dozen wires. They all had black coated ends. The wrap around them said "body builders". Thanks in advance for the help.
Old 11-30-2010, 11:31 AM
Make sure its the solid orange wire not the one with the stripe on it. I almost made that mistake last night.
Old 11-30-2010, 04:55 PM
It is definitely the solid orange wire. I tested with a volt meter and am getting 12v from it.
Quote:
high idle mod f350ranchand 6.0L Power Stroke Diesel 3 11-11-2012 08:26 PM
Fog Light Mod ZeroTucker 2007 - 2014 Expedition & Navigator 17 05-07-2012 03:03 PM
High Idle Mod nghtrgr Excursion - King of SUVs 14 10-02-2011 05:13 PM
High Idle Mod san antonio 1999 to 2016 Super Duty 3 02-10-2011 11:26 AM
DIY High idle mod?? Krisx125 1994.5 - 1997 7.3L Power Stroke Diesel 12 12-08-2009 12:49 PM
Tags
07, 2004, 2007, 60, add, diesel, f250, f350, fast, ford, high, idle, idol, mod, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
