Hauling an ATV with attached snow plow
I was wondering if any of you had any input regarding a good size for an ATV plow blade. I was thinking of getting a 48 inch wide plow but the the local plow dealer said that most ATV owners perfer the 52 inch plow when angle plowing.
I can back the ATV into the truck bed and the wider plow should be fine, right?
Thanks in advance,
Harold
Thanks in advance,
Harold
If you happen to get the 48", you will plow with the blade straight most of the time, since when you angle it, the bike will be wider than the area being plowed
I have a 60" on my Honda TRX500 and chained up it's move ALOT of snow!! With out chains, you'll get stuck alot...
Good Luck,
Garry in Alaska
Good Luck,
Garry in Alaska
hrsitton
07-30-2002 08:16 PM
