1997 F-250 7.5L Help - Codes 173, 332 - Rough Idle - Ford Truck Enthusiasts Forums
Old 11-29-2010, 03:08 PM
boaterdude83 boaterdude83 is offline
boaterdude83 is starting off with a positive reputation.
We have a 97 F250 with the 7.5L V8. The truck is pulling codes 173 - EGO Not switching, Rich Exhaust Bank 1 and 332 - EGR Valve Not opening.
The truck Idles very rough, and blows black smoke when reved from an idle. It runs smooth at higher rpms though, and seems to have its power. We do have alot of miles on the truck, but until this problem, she ran great. Any help would be much appreciated! I'm trying to get her running well for the winter. Thanks guys!
Old 11-29-2010, 04:27 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
I think I would check the Fuel Pressure Regulator. Make sure that the vacuum pipe going to it is good and then pull the vacuum pipe off the FPR and look for signs of gas in it. If any found replace the FPR.
Old 11-29-2010, 05:49 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
X2 on the possible leaking regulator and if that doesn't look to be the problem then check fuel pressure.
Make sure its not to high, should be,
Engine off key on = 35 to 45psi.
Engine running, FPR vac line attached = 30 to 45 psi.
Engine running, FPR vac line disconnected = 5 to 10 psi increase.
Static pressure leakage check,
Verify that the fuel pressure remains within 5psi of spec for 1 minute after turning engine off.
Old 11-30-2010, 03:55 PM
Engine off key on - Shoots up to about 55 psi, and slowly drops down 20 and below. Engine running 70 - 74 psi (bouncing around). Turn engine off drops right back down to next to nothing. Sound like I need a FPR? Also - On the vac lines there is a small cylinder with 2 vac lines on the top of it and a plug with 2 leads in on. Any idea what this is? Thanks for your help guys!
Old 12-01-2010, 04:14 PM
Put the new regulator on, and It runs so much better. Runs at 30 psi, and holds pressure after being shut down. I was amazed at how much better it ran with the new regulator. Still have the codes, so I'll be clearing them, and I'll be pulling it out tomorrow to run it and see what codes I get. Again though, If anyone has any idea what that vacuum valve is, let me know! I'm very interested to find out what it does. Thanks again!
Old 12-01-2010, 04:27 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
A picture would help but it sounds like the CANP solenoid. It allows fuel vapors from the fuel tanks/charcoal canister to be sucked into the engine.
Old 12-01-2010, 04:47 PM
What rla says, the canister purge solenoid.
351w rough idle, stalling, lack of power Azfordracing Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 11-01-2016 05:37 PM
F350 7.5 codes 542 332 211 help! boggerted 1987 - 1996 F150 & Larger F-Series Trucks 15 10-31-2015 11:36 AM
Emblem location? Ranger1975 1973 - 1979 F-100 & Larger F-Series Trucks 14 06-14-2015 01:32 PM
Code 173 and rough idle stalling BRay09 1987 - 1996 F150 & Larger F-Series Trucks 33 02-25-2011 06:10 PM
4.0 L Running Rich rwdf250 Ranger & B-Series 3 01-30-2004 08:00 AM
Tags
173, 1996, 1997, 58, 75, 75l, aerostar, code, codes, ego, f250, f350, ford, idle, idles, rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
