6.0 Cold start hard shift runs good warm!
Old 11-29-2010, 01:45 PM
JCastellaw's Avatar
JCastellaw
JCastellaw is offline
We have 3 6.0's and they all have the same cold start and hard shift when cold. when it warms up, it runs like a champ. they also have a little noise in the front end when you hit a bump.
Any easy or cheap fixes. Ford dealerships around here could not put a belt on a lawn mower!
Old 11-29-2010, 02:21 PM
brickie's Avatar
brickie
brickie is offline
Try synthetic 5-40 and check the sway bar bushings.
Old 11-30-2010, 10:45 AM
JCastellaw's Avatar
JCastellaw
Will seafoam cure it?
Old 11-30-2010, 11:43 AM
PSD2005's Avatar
PSD2005
PSD2005 is offline
if it's a sticky injectors it will help.run at least 2 cans in oil and run diesel klean double the amount in the tank.Run it hard for a good hour,then you will have to change the oil.Most likely the oil will be very dirty full of soot.If this does not help,most likely one or more injectors will need replace.Hope this helps ALSO if it does help run 5-40 syc to help with other sticky's
Old 12-01-2010, 05:04 PM
JCastellaw's Avatar
JCastellaw
they smoke like hell when they are cranked!
firemedic1237
1999 to 2016 Super Duty
23
09-20-2022 07:17 PM
Alex24
10-03-2020 09:44 PM
BarterOnlycom
04-26-2013 08:33 PM
Orangew0lf
02-28-2012 09:17 AM
shane h
08-24-2009 03:49 PM
Quick Reply: 6.0 Cold start hard shift runs good warm!
