7th gen spotter's thread
#47
As 81_Explorer previously pointed out, it is nearly impossible to tell what year that is. The clear park lamps were also used in 1981. However, it looks to have the Free Wheeling pinstripes. The black grille also was offered on the Free Wheeling pickups.
On a side note, the blue/white Flareside in that image from the 1981 brochure features one of the rarest options Ford offered on the 80-86 trucks, factory fog lights. For even more fun, my 1980 brochure features both the red free wheeling longbed, and the blue/white flareside, just like the 1981 brochure. However, in my 1980 brochure, the red truck has the fog lights, while the blue/white truck does not.
#51
#52
Definitely very, very rare, especially if the housings are still intact. If they are factory, then you will have the special fog light switch molded with the instrument cluster, to the right of the headlight and wiper controls. If you don't have this, then they're not factory, or your bezel has been swapped.
#53
The bezel that came with the truck had the switch there, I swapped it out for another unit,because it was broken, but kept the switch The lights are complete, It was an old man truck, so it didn't see much use. The lights are in the garage, probably buried, I'll look this week end, and get some pics.
#54
#55
#56
#58
on
Well, it's either a 1980, or an early 1981 before a build date of 12/80.
#59
I don't have the power mirrors, nor do I care to have them, but if you come across a set, grab them up if you can. This is the only picture I have ever seen of them, and it's just a picture of the switch. Apparently the mirror that was used for power was the swing lock type.
