What trans to fit a 300 I-6? - Ford Truck Enthusiasts Forums
Old 11-29-2010, 12:48 PM
hivoltj's Avatar
hivoltj hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
Hey guys, I'm swapping an '89 EFI 4.9L into our '64 F-100 4x4, wondering what trans (stick) that these trucks used that would bolt up. From what I can find, my truck originally came with a 292 V8, BW T-18 and a Dana 24 transfer case (divorced). The trans code on the data plate is "F".
I was going to use the 5-speed out of the donor truck, and it's married t-case, but I'm thinking how much easier it'll be to not have to re-figure driveline angles, hydraulic clutch plumbing and such, and I may be needing the 5-speed for the wife's truck, as the E4OD is on it's last legs.
Is there a bellhousing to mate a T-18 to the 300 block? If not, what trans swap would be easiest? An NP435? There is one on Craigslist local to me cheap, got me thinking.
What manual transmissions were available in slicks with the 300 I-6?
Old 11-29-2010, 01:17 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
If you have a truck bell, the T18 or np435 will work. Depending on your axle ratio, you may wish you had OD.
As for replacing an E4OD with a stick, remember the computer will miss that E4OD, so you have to fiddle with that as well.
Back to the six: if you have the right bell, just about any trans will bolt up. Bell to engine is the same as SBF, so everything from old 3 speeds to the ZF 5 speed will work.
Old 11-30-2010, 12:34 PM
hivoltj's Avatar
So you are saying that there IS a production bellhousing to fit a 300/302/351 pattern and a T-18? What about the clutch?
I guess I haven't asked for sure, but assumed the 292 bellhousing pattern is different.
Overdrive won't be missed, this truck will problably never see the highway. It'll be an in town cruiser/ shop truck.
Old 11-30-2010, 03:21 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
The T18 was used from 56 to 73 and then replaced by the T19. Your 1964 T18 will not bolt to any bellhousing produced from 1965 on as the input shaft and bolt pattern was changed for 65.
All 300 and Windsors either used a 10" or 11 " clutch and pressure plate depending on the GVRW. Most aftermarket replacement flywheels are drilled for either pattern and all use the same spline count on the clutch disc.
NP435 is a better transmission and will bolt to the Small block bell unless it is a 64 unit. The NP435 is used from 64 to 85 in F series trucks.
Garbz
Old 12-08-2010, 05:59 PM
hivoltj's Avatar
I sure did like the NP 435 in my '78 F150.......
There is one on c-list near me for $80, says it will fit Ford 2wd or 4wd???? How's that possible? I'd assume I would need a 2WD version to retain my divorced Dana 24?
From what I'm finding there was one a 10 spline input for the NP trans, so finding a clutch should be fairly easy?
Old 12-08-2010, 07:28 PM
garbz2's Avatar
58 to 77.5 F250 and 59 to 65 F100 four wheel drives used a divorced T case and the same transmissions as a 2 wheel drive.
Garbz
Old 12-12-2010, 01:32 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F100/350's prior to 1965 came with the Borg Warner T-98. There was no such thing as a Warner T-18 until 1965.
TRANS code F = 1956/64 Warner T-98 / 1965/93 Warner T-18.
1965/66 F100/350 300 I-6 manual transmissions: Ford type 3.03 3 speed manual all syncromesh (F100/250) / Warner T-85N 3 speed overdrive (F100-2WD only) / Warner T-87 3 speed manual (F350) / Warner T-18 4 speed / New Process 435 4 speed.
Old 12-13-2010, 11:48 AM
hivoltj's Avatar
ND, I had found that out after posting that it was a T-98, but didn't bother to mention it, as I had read the T-18 and T-98 share the same case, so I'm still in the same boat.
I'm still going to scrape all the grease off the trans and verify that's what it is before I go looking for an NP435, who knows what could have been swapped in over the years.
Old 08-23-2012, 10:00 PM
One79one71 One79one71 is offline
One79one71 is starting off with a positive reputation.
Im looking g for a bellhousing for a bellhousing will a t18 swell, found a EOTA-7505-FB. Does this work for my 79 f150?
TTB in a 1978 2wd drzensen 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-01-2016 03:39 PM
4.9 trans and intake/carb questions PalumboTruckBully Ford Inline Six, 200, 250, 4.9L / 300 6 07-25-2016 10:53 AM
Trans swap bobs 80 f250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-17-2015 09:20 AM
Wanna swap to a manual trans from AOD to a 4 or 5 speed Eightyfive Flareside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-06-2015 08:48 PM
66 F100 with T18 tranny red and white truck 1961 - 1966 F-100 & Larger F-Series Trucks 6 01-13-2006 04:42 PM
Tags
1978, 300, 49, bell, bellhousing, f100, fit, fits, ford, housing, i6, inline6, pattern, t18, trans, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
