Emissions light/check engine light ?????????
I live up in Washington and we had record cold the past couple of days and one day when i started my truck the little light in the left hand bottom corner of the instrument cluster. I looked it up in the manual and it says that it's the check engine light and that i should check the OBD-II under maintenance and specifications but that really doesn't say much. So do any of you know what it means ?
Thanks
Thanks
If you don't have a OBD scanner, you can take your truck to Advance Auto or Auto Zone and they will scan your truck for free.
Write down whatever codes and descriptions they give you and have them clear it from your truck.
Then come back and post the codes you got here and tell us if your light came back on.
I would make a note of what the codes are, clear them and see if they pop up again as a reocurring problem.
RadioControlGuy85
02-11-2017 07:41 AM
smileyp
Escape & Escape Hybrid
11-05-2016 11:44 AM
coxhaus
08-02-2016 04:02 PM
2005, 2007, 2008, 60, diesel, emission, emissions, emmissions, f150, f250, ford, ligh, light, mountaineer, powerstroke
