Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 11-29-2010, 08:42 AM
bwb1 bwb1 is offline
Garage is empty, add now
bwb1 is starting off with a positive reputation.
7.3 wastegate problem
wondering if anyone has had a problem with wastegate leaking or dumping by itself or if it is another issue. My buddy has a 7.3 powerstroke dp tuner banks intake and exhaust. Tranny was just rebuilt after he recieved his truck back. It seemed to start blowing off really fast while under acceleration u could hear a leak and really would bad flutter after the hard shift! We where thinking waste gate the entire time so he order a banks big head yesterday! But if there is anything else he should know about i would appreciate it thanks!
  #2 (permalink)
Old 11-29-2010, 09:17 AM
Rich in CO Rich in CO is offline
Rich in CO is starting off with a positive reputation.
Sounds like turbo surge which is not a wate gate issue, sound like the waste gate is doing what it's suposed to do. it will dump some boost early on to prevent over boosting. The only way to fix surge is to replace the wheel with a wicked wheel, but that doesn't alway's fix it, the whee in most case cost under a $100.00.
The for sure way to fix it is a lot more pricy in the $400.00 range and thats a ATS ported housing.
__________________
2000 F350 crew cab LB, DP F5 Tuner, Auto Meter C2 guages, Aeroforce Scan gauge, 4" pipe tip 2 tail, BTS, AIH delete, Non EBPV Pedital, CCV mod, Ford AIS W sleve, Zoo Dad, 6.0 tranny cooler, HXSS cross over line, Hutch / pooned tank mod, CCK RR kit, ATS Housing, TM wastegate, DI Up Pipes, 08 Diff Cover, Hawks & Slots, Bilstien 5100's, Pro Comp leveling kit, running 285's
  #3 (permalink)
Old 11-29-2010, 09:23 AM
Pocket's Avatar
Pocket Pocket is offline
Pocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud of
Quote:
It's not the wastegate. In fact, it's impossible to hear the wastegate on these trucks.
As Rich pointed out, it's a compressor surge or stall issue. Surge happens on acceleration or when the engine is somewhat "loaded". You can really hear it with an open intake, and if you have a boost gauge, you can watch the needle bounce up and down rapidly. Stall happens on shifts, where you have higher RPM's, higher boost, then suddenly the RPM's drop, but you still have all this incoming airflow.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
  #4 (permalink)
Old 04-08-2011, 08:58 PM
l_anthony l_anthony is offline
l_anthony is starting off with a positive reputation.
2002 F350 Lariat 4x4 Crew Dually 7.3
Hello, I am having a similar problem. When I am up to 70-75 mph and hit a hill or strong wind, I feel I loose power and hear my engine dieseling like my turbo dropped out? If I put my foot into it to pass, it does the same thing and then throws a code that someone on another forum interpreted as a waste-gate stuck open? I want reliable power on call every time. Do I need to upgrade the compressor side of the turbo like stated above. I thought a rebuild with wicked wheel and performance actuator. Now am I hearing I should think about a new compressor housing and more?
LN
  #5 (permalink)
Old 04-09-2011, 08:14 AM
Pocket's Avatar
Surge doesn't throw a code.
And exactly what codes did pop up?
__________________
Curtis
2002 F-250 PSD
  #6 (permalink)
Old 04-09-2011, 12:08 PM
Code P1249
  #7 (permalink)
Old 04-09-2011, 04:28 PM
Pocket's Avatar
That's a wastegate steady state failure.
Here's the thing... the PCM can only see the wastegate solenoid, the electronic side of the wastegate. It cannot see what's happening with the actuator itself. So if you're getting a code for the wastegate, it has something to do with the solenoid or the wiring.
__________________
Curtis
2002 F-250 PSD
  #8 (permalink)
Old 04-09-2011, 05:54 PM
I throw this code only when passing and getting all the way into it. Also, I have 375,000 miles. Replace the solenoid? Do you have to pull the turbo to change the solenoid? Any advice?
LN
  #9 (permalink)
Old 04-10-2011, 02:56 AM
Pocket's Avatar
The solenoid sits right on the very front of the intake spider.
However, before trying to spend money on swapping parts, what does your boost look like?
__________________
Curtis
2002 F-250 PSD
  #10 (permalink)
Old 04-10-2011, 12:49 PM
boost max is 16 psi, when there it will diesel, loose a lot of power and throw this code. At 2000 rmp, while working to get out of sand if 4wd, I show 3lbs.?
LN
Tags
01, 1996, 73, 73l, 73powerstroke, bad, duty, f250, fix, ford, gate, problems, super, waste, wastegate, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
