5 Speed Tranny for 390?? - Ford Truck Enthusiasts Forums
Old 11-28-2010, 10:32 PM
68Ford4Life's Avatar
68Ford4Life 68Ford4Life is offline
68Ford4Life is starting off with a positive reputation.
So I've been looking and I can't find what I want to know. Is it possible to get a 5 speed transmission for my 68 Ford F-100 with a 390FE? I currently have the original 3-speed automatic transmission and I'm only gettin 7 miles per gallon. I was hopin to get a 5-speed stick...any help?
Old 11-29-2010, 02:29 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Not as a straight bolt in...you'll probably have to get an adapter of some sort and plan on doing some modifications to make it all work. A lot of 5-speeds (like the ZF) have integral bell housings and none of those were ever made to fit the FE block.
But 7 MPG out a a 390 in an F-100 is pretty low...unless you have a number of mods done to it and have a lead foot! I'd say you have some other issues you need to address to get you up into the standard 10-14 MPG range that most of us see.
The closest thing to straight bolt-in I can think of (just speculating wildly here) is the Getrag 5-speed offered in the Dodge trucks when they first started offering the Cummins ('89-'93) before they switched to the NV4500 due to reliability problems with the Getrag. The Getrag, for some reason, was built with the standard Ford transmission bolt pattern so it will bolt up to a Ford bellhousing. But the Getrag input shaft is both larger diameter and longer than the Ford, (like the typical NP-435 4-speed) so you'd need a spacer and an appropriate clutch disc, and it's probably still not worth the hassle due to the fact that the Getrag is a POS, though the likelihood that it would hold up better behind an FE than the Cummins is probably pretty good.
This has come up a number of times already and there have been a number of solutions tossed about, but off the top of my head I don't recall what alternatives were offered. Perhaps some others will chime in here...
Old 11-29-2010, 03:02 PM
northerndave's Avatar
northerndave northerndave is offline
northerndave is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by TigerDan View Post
and it's probably still not worth the hassle due to the fact that the Getrag is a POS,...
That cracked me the hell up
Old 11-29-2010, 04:48 PM
TigerDan's Avatar
Glad I could help make your day...
Old 11-30-2010, 06:37 PM
Ok, I have been lookin at the T5 transmission by Borg Warner, could that be made to work?
Old 11-30-2010, 07:08 PM
davethecow davethecow is offline
davethecow is gaining momentum as a positive member of FTE.
The clark 5 speed found behind 361 and 391 FT motors in f600 and f700 trucks from the 70's can be made to work.
You will need a custom flywheel. They are a big heavy transmission and the final gear is 1.1 same as the np435. but it has closer gear spacing and a lower 1st. Use with tall gears in the rear and that would work.
Old 11-30-2010, 07:53 PM
TigerDan's Avatar
The T5 has a different bolt pattern than the standard Ford transmission pattern, as well as a longer input shaft so yes, it could be made to work with an adapter/spacer between the bellhousing and transmission.
However, even the World Class T5 would be marginal in its ability to stand up to the torque of even a stock 390. The WC T5 is rated at 300 ft/lbs of torque while a stock 2bbl. 390 puts out around 375, so you can see it's not a good match. The T5 can be upgraded to handle more torque, but it's not cheap. By the time you're done, you might as well have just bought an NV4500 and swapped that in instead.
Check out the Domestic Truck Tranny Guide for tranny identification and ideas of what's available:
Old 12-01-2010, 05:19 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Speedway motors makes a new steel bellhousing for FE engines to accept a T-10 Four Speed T-45 or Tremec TKO 500 or 600 transmissions.
I believe a TKO 500 will live quite well behind a fe as it is ratted to 500 FT#
They also offer the same type bell for 385 series big blocks.
Garbz
Old 12-01-2010, 07:58 PM
Victor L's Avatar
Victor L Victor L is offline
Victor L is starting off with a positive reputation.
Do you have any idea what gear ratio you have in the rear ?
If they are pretty low, like 4.10 to 1, maybe you might want to consider
highway cruising gears like 3.50 to 1, or possibly 3.00 to 1, and keep the transmission you have. Might be more simple.
big block 390 68ford390 1967 - 1972 F-100 & Larger F-Series Trucks 9 01-07-2015 09:33 PM
front end vibration/shaking randyj68 1967 - 1972 F-100 & Larger F-Series Trucks 13 11-09-2014 09:44 PM
Is there any 4/5spd auto i can bolt up to my 390? Mike68 1967 - 1972 F-100 & Larger F-Series Trucks 14 01-17-2013 02:20 PM
4-speed to 5/6-speed Pettybonz Clutch, Transmission, Differential, Axle & Transfer Case 39 03-20-2011 04:28 PM
harmonic balancer rockbasher 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-26-2010 02:00 PM
Tags
390, 56, 5speed, bolt, f100, fe, ford, make, motor, motors, pickup, speed, trans, transmission, wod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
