V10 Rod Bearings going out
2004 V10 EX Limited 105K
Heard raddle. Drew Ford determined the rob bearings were going out. Said I need a new engine $8K. Can this be fixed outside of going to the dealer? I'm not a mechanic but if I find one I trust could they fix for cheaper? PLEASE HELP.....
demery
demery
Ask around for a reputable mechanic. I know that sometimes that is a hard thing to find. But usually a non-ford Mechanic rates are a fair bit less than the Ford rates. The other option is to find a mechanic that will take a "take-out" V-10 from a wrecked truck and then drop that in. BUt you may find out that the labor charges will make it more cost effective to have your engine rebuilt than to have a used one installed. With the economy in San Diego, you should be able to find a mechanic that will give you a decent deal.
Good Luck,
Garry in Kodiak, AK
(Used to be stationed in San Diego for many years between 1986 and 2003)
Good Luck,
Garry in Kodiak, AK
If its only rod bearings you should be able to replace the rod and main bearings with the motor in the truck.
Remove oil pan
Slide the tranmssion back and transfer case if 4x4.
Remove crank from engine inspect journals, inspect rods, replace bearings gaskets and seals. If crank is good polish crank.
You just may get this done for about 800.00.
There is no need to replace an engine that just needs bearings.
Remove oil pan
on my old s15 jimmy i use to have, my bearings went out due to coolant leaking into the oil. intake gasket was leaking. water doesnt make for a good lubricant!!!!
Remove oil pan
Remove oil pan
Yea, but dude said he wasn't a mechanic.
Remove oil pan
Remove oil pan
OR
Are you a victim of a lazy tech.... the ones who hear a knock and say you need a new long block or feel a transmission slip and say you need a reman transmission.
Problem with this
Remove oil pan
Remove oil pan
