Drop the Pan?
Drop the Pan?
Hi there, new to the forum. I have a 69 Thunderbird with the 429 Thunderjet. The casting numbers show that it is a 68 motor with C8VE-E heads. I have lots of plans for this motor but for now just a quick question: Is it necessary to drop the oil pan to remove the timing cover? It sure looks that way....
Bummer... It appears to have been replaced in the past - not sure with what material though. How much clearance at the front of the pan would I need? 1/2" maybe? I wonder if I could get by with a good cleaning and some black RTV... There is only about an inch between the pan and crossmember.
