Oil pressure sending unit question. - Ford Truck Enthusiasts Forums
Old 11-28-2010, 11:58 AM
Anafiel's Avatar
Anafiel Anafiel is offline
Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.
I'm confused.
Yesterday, my dash oil pressure gauge dropped to the lowest position of the normal range, and just kinda stayed there, regardless of RPM.
As I don't have a mechanical gauge just this second to test true pressure, I thought I would do a couple simple tests to try to eliminate whatever I could. I read doing a Google search, that I could test the sender and gauge by pulling the sender wire.
According to the articles I read:
Key on, engine off: Gauge should read "0"
Key on, engine off: Pull wire off of sender, gauge should peg to high.
Key on, engine off: Ground sender wire and gauge should come back to "0"
But mine does the opposite. My gauge shows "0" UNTIL I ground the sender wire with key on. Then it goes full over!
Am I missing something? I'm assuming my gauge might be just fine. I'm hoping it's a sender. I can't afford replacing a pump just now.
Any ideas?
Old 11-28-2010, 12:40 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Ford changed the way the gauges operate sometime in the mid-late 80s or early 90s I forget
exactly. The early versions peg all the way to the high side when that wire is grounded and
flat-bottom to 0 when disconnected, the later models are the exact opposite. Same for the
gas & temp senders, they all operate in the same fashion.
In any event, it sounds like your gauge & wiring are good *at the present moment* (but IVR
problems are generally sporadic which could potentially cause weirdness).
Yes, the best test is to get a known-good gauge to hook up and run your test with that,
anything else is just spinning your wheels IMHO.
Old 11-28-2010, 07:44 PM
Anafiel's Avatar
Got a new sending unit today. Also got a little SunPro mechanical oil pressure gauge to mount down low where I can see it good. The guys at O'Reilly's were great in helping me build a little "christmas tree" so that I could have both the sending unit and the new gauge working, at the same time. No way I'm gonna have a "dead" gauge in my cluster after all the work I've done to get everything working.
Ran out of light, so I can't install any of this till tomorrow.
Quick question though...
Engine has been running smooth as glass, water temp gauge runs cool (replaced water pump last month, got good coolant), no lifter noise, nothing to indicate any major issues anywhere. If the engine was losing pressure due to wear, wouldn't the drop be gradual, and wouldn't I see that in other performance indicators as well? And what about the oil pump...would it drop to a low pressure situation, and just hang there?
This is a sending unit issue, right???
Old 11-29-2010, 02:52 PM
Anafiel's Avatar
Fixed. Changed the sender, and added a little SunPro pressure gauge on a tee at the sender extension. Here's what the mechanical gauge tells me:
Cold start: 55-60psi
Full operating temp, in Drive (450rpm) 17-18psi
Full operating temp, in Park (650rpm) 22psi
1000rpm 35psi
1500rpm 45psi
2000rpm 50-55psi
Dash gauge indicated normal range, very little movement though... I'm glad I got the SunPro gauge!!
Old 08-15-2016, 09:05 PM
Jayson Moe Jayson Moe is offline
Jayson Moe is starting off with a positive reputation.
Need some help please
1000rpm 35psi
1500rpm 45psi
2000rpm 50-55psi
Will driving with a bad sensor/sending unit affect anything mechanically? I currently just ran into this problem.
Old 08-16-2016, 01:06 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
No. It's just to tell you the pressure by moving the gauge. The 460 trucks do have another sensor/switch along with the guage sending unit and if that one goes bad, the truck will not run.
maytag906's Avatar
maytag906 maytag906 is offline
maytag906 is gaining momentum as a positive member of FTE.
no, you just will not have any idea of what you're oil pressure is. My dash gauge quit about 3 weeks ago, but the aftermarket under dash unit shows all is well.
Old 11-15-2016, 12:44 PM
rbond's Avatar
rbond rbond is offline
'86 F-350 XL
rbond is starting off with a positive reputation.
1000rpm 35psi
1500rpm 45psi
2000rpm 50-55psi
Anafiel... are you still there? I see this post is old... hope you're still around.
Q for you... what Oil pressure sender did you end up getting? Was it one of the canister (bell shaped) ones? I'm trying to convert my in-dash gauge from the "idiot" version to the "I'm sort of telling you what your oil pressure is" version.
My current sending unit is simply a switch... on or off... and I'm trying to figure out what ACTUAL sending unit will be compatible Ohm-wise with the in-dash gauge... do you remember what it was that you ended up installing?
Cheers!
Changing Oil Pressure Switch to Oil Pressure SENDER What is THIS? Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-26-2016 10:56 PM
How to test fuel pressure gauge/sender gramicko 1999 - 2003 7.3L Power Stroke Diesel 0 11-03-2015 12:32 PM
OIL PRESSURE GAUGE PROBLEM wcerqua 1987 - 1996 F150 & Larger F-Series Trucks 6 02-20-2012 08:11 PM
aftermarket oil pressure gauge problem 88grandmarquis 1987 - 1996 F150 & Larger F-Series Trucks 19 07-12-2011 10:58 PM
Solution to oil pressure gauge pegged Tifford Electrical Systems/Wiring 4 09-25-2010 09:31 AM
Tags
1985, 2009, 300, block, f150, ford, gauges, ivr, light, oil, pressure, problem, sending, sporadically, straight, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
