Questions on plow plates for 97 F250 xlt - Ford Truck Enthusiasts Forums
Vermont Chapter Join Chapter , Leader: wildstang
Old 11-28-2010, 10:13 AM
JWyckoff JWyckoff is offline
JWyckoff is starting off with a positive reputation.
I know I am stepping into a tight spot here, but I really would like to plow in a truck cab this winter rather than outside, backwards on my farm tractor! I think you all know why..... I have a 97 F250 xlt road worthy "farm" truck. I found a 95 3/4 ton (F150?) with a plow <$1000. The big question is will the plates fit my truck.... Anyone?
I also have the typical rust under the rocker panels. Any idea how much I am looking at to have cut out and welded in? Ball park is fine.. Tips, tricks, buy new, etc.
Thx;
John in Grand Isle.
Old 11-29-2010, 09:10 AM
more info
The current truck is a F250 (not F150). So the simple question is - Will a 95 match a 97 for push plates.... I am hearing most Fords are the same configuration for the plates.
John in Grand Isle
Old 12-01-2010, 08:04 AM
wildstang's Avatar
wildstang wildstang is online now
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
As far as I know the frames are the same. Safest bet would be find out make and model of the plow and call a dealer.
The rockers I would estimate $500 at least if not closer to $700.
You mentioned you live in grand isle so you can become a member of the Vermont chapter. All you need to do is request membership. We do a monthly BS thread for fun and to meet members of other states. December is located here.
http://www.ford-trucks.com/forums/10...ml#post9623816
Old 12-01-2010, 05:44 PM
7283-F250's Avatar
7283-F250 7283-F250 is online now
NH Chapter lean pawn
7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all7283-F250 is a name known to all
Welcome to the site.
'97 is the year they used the new F150 style on the light duty F250's. I know the light duty F250's in 97 have 7 jugs. If you have HD 250 (same body style as the 92-96 F150 through F350) than the 95 3/4 ton (3/4ton is a F250) than you should be fine to swap everything over. Are the body style's the same? That is a good tell.
Old 12-02-2010, 10:27 AM
wildstang's Avatar
VT Chapter Ldr
Good point Dan forgot about the light duty 250.
Towing sway question TNRTL2 Excursion - King of SUVs 13 08-07-2012 10:05 PM
PLOW LIGHT WIRING????????? fordyduty 1987 - 1996 F150 & Larger F-Series Trucks 2 01-19-2010 02:10 PM
CoonAss stl1 Louisiana Chapter 13 04-06-2008 06:27 PM
Anyone Plow Snow W/F150 rcm800 2004 - 2008 F150 6 01-20-2005 11:16 PM
Fisher 8' minute mount geneb11 1978 - 1996 Big Bronco 7 01-08-2003 09:57 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 2004, 94, 96, 97, duty, f250, f350, fit, light, plates, plow, plowing, push
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
