New aftermarket oil cooler - slightly larger holes for coolant flow
#91
My take is that there is a need to develop either a remote cooler that does not comprimise the cooling capacity or a new idea that preforms better all the way around. I also think as with a lot of things 6.0 related there is the fact that people don't maintain their vehicles. A coolant filter and proper coolant maintence will do wonders for a stock cooler... Is there not a way to expand the hd replacement oil cooler so it has enough surface area since the flow is improved? The idea though of adding a restriction to the hiflow cooler to mimick the stock cooler though makes it as flawed as internationals design. (Which I don't think is exactly flawed more abused thru lack of maintence)
#92
#93
Reasonably Priced? (I understand your R&D and Testing gotta be added in) I want everything you make, but my pockets just aint big enough! LOL
#95
Price point and field service are 2 reasons. A stock type cooler is going to plug. Unless you are the maintenance king... so cooler availability makes using a stock, buy at any dealer a better solution for most people. It also solves the cold weather issues we had prior to our cold weather kit development. Further our 6.4 kit needed a smaller cooler due to a severe lack of mounting space.
#96
confused
I am new to this forum and have to say this thread and forum are fantastic compared to the other auto forums I have been on.
After all this discussion I am now confused on what to do with my 06 6.0 dually. EGR cooler is plugged and would like to go to an upgraded tube version instead of bypass or delete with a new oil cooler.
With these options from bullet and innovative and what may be coming out I am lost. Unfortunately I cannot wait for the new options because I cannot keep driving with a plugged egr cooler and most likely a plugged oil cooler while cleaning the egr valve when it sticks.
Not really asking for advice, just thanking you all for participating in this thread and all the information it brings to light without everyone bashing and insulting each other.
I have to say that working on my dragsters and their engines is a lot easier than the truck that pulls the trailer to the track.
Thanks again, without your help most of us would be lost in the woods.
Scott
Scott
#97
#98
I KNOW..... It takes FOREVER to get this stuff done. The 6.4 kit is in testing still. The 6.0 E-series kit is finished. Just waiting on the installation manual and a production run on some hard lines. We are in the late stages of developing an improved turbo oiling system, an alternate 6.0 system and an alternate 6.4 system. Both mid range priced. Our FICM power supply design should be in prototype testing within 2 weeks.
Light bars... Fire extinguisher mounts.... New cooler designs... Truck racks... All coming soon...
Also check this out: www.riptothetip.com
We are once again using 2 of our BPD Superduties as chase support all the way down Baja to Cabo. Baja is an awesome proving ground. Check out the names on the list of riders... It's going to fun!
#100
#101
#102
Just got my truck back yesterday from the shop. New HPOP, new IPR, new oil cooler, new egr cooler and egr valve. Flushed and filled with fresh coolant and oil.
What do I need to do to keep from having all this replaced in the next few years?
Coolant filter?
is that key to helping stop the clogging?
Coolant filter?
#105
