I know I asked this before but I can't find the thread.
Where you get a kit to the add the clear cab lights to a truck that doesn't have can lights. I want the ones that have clear lenses, bulbs, but the light is amber when lit.
there you go sir, i bought these ones, 100$ on my door step in 2 days! its not really a kit persay, its 5 lights, you get some wire and some connectors, i needed an extra foot or 2 of wire and 5 more connectors to run the wire. only enough for the positive, no ground wire. i just tapped mine into the fuse panel.
I was going to tap into my corner lights in my headlights with an inline fuse. but then i realized our trucks have a plug on the passangers side kick panel. Taping into the fuse panel has alwaysss sketched me out. IMO
If you look in George's pic you'll see a red triangle thing in the harness. You can pop that thing out with a small screwdriver and pull out the wire you need to access then it doesn't have to be cut.
