I have a 2000 V10 with the most awful spark knock you've ever heard. Fuel pressure within spec and exhaust has no restriction. Knock sensors ever go bad?
I'm not sure what you mean by spark knock BUT is it possible it may be trying to spit out a plug ??
No it's not trying to spit a plug. They're new and seated properly. Detonation is what I'm talking about. Pinging
Those are 2 terms I DO understand & the only ways that I know they can be caused is by ,the timing being too advanced, Engine under severe load with the crap they sell as gas now a days,Or using a low octane fuel in a high octane required engine....
I'm not familiar with the V10's, but do they have VVT (Variable Valve Timing)? My Lincoln had the worst pinging I've ever heard at full throttle which was due to a bad VCT solenoid. It took me awhile to track it down. Disconnecting the VCT solenoid eliminated the pinging completely.
Is the pinging accompanied by a loss of power, especially at higher RPMs? If so it could be a clogged catalytic convertor, checking the pressure at a pre-cat O2 sensor will be the best check.
You never answered what plugs you swapped in. Also you might think about running non-ethanol fuel in your truck. It's all I run unless I run low and can't get to any.
