S. California Chapter Join Chapter, Leader:
intake manifold question
Old 11-27-2010, 07:25 PM
lucky_strike's Avatar
lucky_strike
lucky_strike is offline
my engine is a 360 i can get a intake manifold for it for cheap but it says its made for the 390 and higher, i thought the 360 and 390 where the same so would that fit mine?
Old 11-27-2010, 08:18 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Yes it'll fit.
Old 11-27-2010, 09:47 PM
lucky_strike
thanks for the quick response!
Old 11-27-2010, 09:58 PM
SteveBricks
I'm guessing the manifold you're looking at is for a 4bbl carb...that's probably why it says it's for a 390. I don't believe there were any 360's offered with a 4bbl from the factory.
Old 11-28-2010, 10:58 AM
lucky_strike
yes ill be getting a 4bbl 800cm from edelbrock when i get the intake
Old 11-28-2010, 11:06 AM
SteveBricks
That's a lot of carburetor for a stock motor.
Old 11-28-2010, 04:23 PM
edsf100's Avatar
edsf100
edsf100 is offline
600 CFM would work better if stock. I had a 750 and like the 600 much better. 360,390,460 all built on the same 352 block. Intakes all the same. not many to to pick from. Check out this thread on the 390fe
390 FE help needed - THE H.A.M.B.
Old 11-28-2010, 07:38 PM
lucky_strike
only non stock thing in the engine is a cam. not 100% about that either
after reading that i think i will go with the 600 cfm, i always thought bigger was better.
Old 11-29-2010, 12:06 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
The 460 is a completely different block.
Maybe you meant the 427?
FE's I haven't forgotten, and the 460 isn't one of them....
A good lesson to learn early is that that's not always true.
You need to keep the air flow velocity through the venturis high enough to atomize the fuel properly. You don't want an excessive amount of restriction to do that, but properly sizing the carb to the displacement and red-line will bring more joy that just a "big carb".
Pop
Old 11-30-2010, 01:06 PM
lucky_strike
wil i need to buy a new transmission kickdown lever or can i use my old one?
Old 11-30-2010, 01:42 PM
SteveBricks
I guess the question is if the kickdown linkage is the same for a 2bbl and a 4 bbl...if it is you should be able to use the one you have with a "direct replacement" carb that's specifically for a 390 4bbl/w a C6 automatic. Probably wouldn't be a bad idea to contact the company you're buying it from to be certain about the carb, and maybe start a thread over in 67-72 to see if anyone can tell you if the linkages are identical.
