Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 11-27-2010, 04:15 PM
BRay09's Avatar
BRay09 BRay09 is online now
Garage is empty, add now
BRay09 is gaining momentum as a positive member of FTE.
What to use for bed bolts?
Will standard carrage bolts work for the bed on a 89 F250? If not, what did others use for theirs? I had to cut mine off and dealer says they dont have anything for me.
__________________
Guzzy
1989 F250 Custom
351W with Crane 444232 Cam, 1.7RR in GT40 heads, summit shorties (waiting on Pacesetter LTs)
Isn't the fastest thing, but we will pull your house down
  #2 (permalink)
Old 11-27-2010, 04:21 PM
danr1 danr1 is offline
danr1 has a very good reputation on FTE.danr1 has a very good reputation on FTE.danr1 has a very good reputation on FTE.danr1 has a very good reputation on FTE.
I used Grade 8 from the hardware store, I had to cut the stock bolts to remove them.
Carrage heads are not strong enough IMO for the task, generally only grade 2.
I used standard hex bolt then used an angle grinder to kinda round off the heads some to resemble the stockers after they where tight, you know so stuff wouldn't tend to snag on em as easy.
__________________
87, 94, 95 F250
05 Chevy Impala
  #3 (permalink)
Old 11-27-2010, 04:34 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
if you send me your address i have an extra set of factory bolts here. i took the ones off my truck when i did the body lift so i dont need them anymore. just pay for postage. i used standard grade 8 hex bolts on mine, but they sometimes catch on stuff, and you need 2 people to install and uninstall them. the factory ones are a 1 man job.
__________________
1990 F-350 LARIAT 4x4 7.3L IDI diesel ZF5. 1992 front with cowl induction hood, 1997 doors and tailgate. 2004 6.0l intercooler, PSD heated power and signal mirrors. AMSOIL bypass system, full synthetic system. 5.38's, 46" tires, 20" wheels, 12" lift with shackle reversal front, shackle flip rear. Ladder bars in the rear, 2" hydraulic assist steering, hydroboost brakes, onboard dual compressor air system. twin air horns, black interior, 100 gallon in-bed tank. 94 IDI-T motor, SMF conversion.
  #4 (permalink)
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
You can get factory bolts from Ford, several aftermarket places, even ebay.
Why use junk when you can use the real thing. Plus, the official bolts self-keep in the holes of the bed and don't spin when you tighten the nuts.
  #5 (permalink)
Old 11-27-2010, 05:14 PM
Well heck then better go with the Taptite2000 fasteners the newer models use! LOL
Just one man and working from the top to boot.....
__________________
87, 94, 95 F250
05 Chevy Impala
  #6 (permalink)
BRay09's Avatar
Quote:
Thanks i think ill just get some bolts from the hardware store like advised. It needs to be on sooner, rather than later. Appreciate it though
__________________
Guzzy
1989 F250 Custom
  #7 (permalink)
Old 11-27-2010, 05:22 PM
no problem. just expect about $2 a bolt.
__________________
  #8 (permalink)
Old 11-27-2010, 06:16 PM
tjc transport's Avatar
tjc transport tjc transport is online now
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
you can still buy them from ford. i bought a set 3 weeks ago. stock items off the shelf. the problem is that they are no longer listed in the computers.
but they are still listed in the microfilms, the problem is finding a parts man that knows how to read a microfilm.
give me a few and i will try to find the part numbers for you.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #9 (permalink)
Old 11-27-2010, 06:22 PM
here are the ford part numbers for the bed bolts.
*N803022*S40 @ $12.62
*N803020*S40 @ $6.90
*N803023*S40 @ $9.90
and the nut part number is
*N620483*S437 @$1.62
you will need 2 of each bolt, and 6 nuts.
these part numbers prices are from parts guy ed, a site sponsor.
http://partsguyed.com/
__________________
Tom
  #10 (permalink)
Old 11-27-2010, 08:25 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.LARIAT 85 has a great reputation on FTE.
Thanks for the info, tjc transport!
__________________
1985 Ford F150 XLT Lariat
*302: 0.060 over, CompCams 31-230-3, "Thumper" E7 heads, Edelbrock Performer intake, Autolite 4100-4V, Duraspark II, Thorley Tri-Y headers, Flowmaster 40 true duals
*AOD transmission
*2wd, 3.55 gears
Quote:
Life is too short to have anything but delusional notions about yourself!
  #11 (permalink)
Old 11-27-2010, 09:35 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old, tired and grouchy
1993 Ford F-250
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
You can get grade 5 and grade 8 carriage bolts from a fastener supply house, hellava lot cheaper than those prices!
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
  #12 (permalink)
Old 11-27-2010, 10:22 PM
BRay09's Avatar
Quote:
Thats what i was thinking. But do those bolts from teh factory do something that the carriage bolts wouldnt?
__________________
Guzzy
1989 F250 Custom
  #13 (permalink)
Old 11-28-2010, 05:11 AM
Quote:
yes. the shank is oblonged the full length of the bed instead of just the small square head like a carrage bolt.
here is a pic of 2 of the 3 different size bolts
Click the image to open in full size.
__________________
Tom
  #14 (permalink)
Old 11-28-2010, 10:15 AM
CWPottenger CWPottenger is offline
CWPottenger is starting off with a positive reputation.
LMC has the bolts
Tags
1990, 1997, bed, bolt, bolts, carrage, f150, ford, n803020s40, nut, ranger, size, special, spring, transport, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
