Fuel Leak 01 7.3L PSD - Ford Truck Enthusiasts Forums
Old 11-27-2010, 04:01 PM
Ba24dupont Ba24dupont is offline
Ba24dupont is starting off with a positive reputation.
I have a fuel leak on my 01 F-250 7.3L PSD and I think it is coming from around the fuel filter housing. The valley on the top of the motor has fuel on it and it looks like it is running off the back of the motor. It only leaks when it is cold ( 35 and below ). During the summer it did not leak, just wondering if anyone has had this problem and if so what it where it might be coming from. I have looked all over and can't find it. Any help will be appreciated!
Thanks in advance!
Old 11-27-2010, 04:20 PM
KH85's Avatar
KH85 KH85 is offline
KH85 is starting off with a positive reputation.
I just had the same problem. Its probably coming from your fuel bowl drain thats where mine was leaking from.
You'll want to take off your drain and flip the o-rings around and snug it up nice and tight and see if that fixes it. If so you need new o-rings for the drain. Which you can get from Guzzle.
Old 11-27-2010, 04:27 PM
swissone swissone is offline
swissone is starting off with a positive reputation.
Check your water seperator valve, I just replaced mine but it was leaking down the fuel drain. In the cold weather the plastic and aluminium expand and contract at different rates your fuel filter bowl might be cracked as well. check this site out I found it really helpfull. Welcome to guzzle's Ford PSD Maintenance Web Page
good luck
Old 11-27-2010, 04:30 PM
KH85
Thanks for the info, it looked to me like it might be coming from there, That is the yellow cut on/off lever you are talking about that drains the fuel filter bowl?
Old 11-27-2010, 04:38 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
That's the one. IIRC those screws are TORX head.
Old 11-27-2010, 04:40 PM
KH85's Avatar
Yeah thats it. Has four screws on the side of it, I believe there #20 torx heads.
Just need to drain the bowl, remove the bowl drain hose, pull out the screws take the drain off and use a pick to pull out the 2 o-rings and turn them around and reassemble.
DO NOT try to remove the o-rings that are in the fuel bowl itself, just the ones on the drain.
When I did mine I also removed the leads on my gpr, and the wires the hook to the intake Y, and the AIH as well I think. Just to make it easier to get in there. Its a perty tight fit especially if you have big hands. Also have an extend-o-magnet thing handy for when you drop everything down into the engine V! haha
Old 11-27-2010, 04:42 PM
thats the one, check that link out it was really helpfull.
Old 11-27-2010, 07:02 PM
Thanks to everyone who replied to my problem! I will try this and see if that fixes it.
Thanks Again
2001 7.3L fuel leak Budlight7 1999 to 2016 Super Duty 5 04-10-2014 03:42 PM
Fuel Leak george horner 1999 - 2003 7.3L Power Stroke Diesel 4 04-01-2012 09:39 PM
oil leak? coming from top of motor? przao1157 1999 - 2003 7.3L Power Stroke Diesel 8 05-01-2009 04:18 PM
1997 ford psd fuel leaking oldirtracer 1994.5 - 1997 7.3L Power Stroke Diesel 6 08-18-2006 05:17 PM
Oil Leak ??? :( mcbryant 1999 - 2003 7.3L Power Stroke Diesel 16 06-10-2003 12:56 AM
Tags
2001, 2003, 73, 73l, bowl, cold, f250, filter, fuel, heads, leak, powerstroke, psd, remove, removing, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
