Super Tube 6.2L Intake - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 11-27-2010, 11:02 AM
fordmdb's Avatar
fordmdb fordmdb is offline
PREMIUM SPONSOR
fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.fordmdb has a great reputation on FTE.
Hi Guys
I thought i would share we have been working on this concept for Super Dutys and Raptor 6.2L intake..
__________________
Custom Tuning for F-E-Series Engines 6.8L V10 / 5.4L V8 / 4.6L V8 / 6.2L V8 / 5.0L V8 / 3.7L V6 / 3.5L V6 / 3.5L EB / 2.7L EBand more!
SCT Custom Tuning Dealer
www.5startuning.com email me here:sales@5startuning.com 843-536-1244
https://www.facebook.com/pages/5-Sta...92086367552400
Old 11-27-2010, 11:08 AM
drh1175 drh1175 is offline
drh1175 is starting off with a positive reputation.
Looks great! How does it compare to the OEM? I am getting my new 6.2 soon and am looking for something up that alley!
Old 11-27-2010, 11:16 AM
LMS Residential's Avatar
LMS Residential LMS Residential is offline
LMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputation
Damn Mike, did nearly identically the same thing to my 5.4 only I shot it in black hi temp enamel.
In particular I like the wump sound when you step into it. Might be my wishful thinking but there seemed to be a little more get up in higher rpm ranges like 3 - 5000.
Old 11-27-2010, 11:27 AM
fordmdb's Avatar
PREMIUM SPONSOR
Thanks guys, Stock tube at maf is 80 mm ish.. this tube would be 89 mm with a dry filter on the end...
__________________
Old 11-29-2010, 08:08 AM
devongarver devongarver is offline
devongarver is starting off with a positive reputation.
What are the functions of all of the factory hoses that are connected to the intake tube? I know there is usually one that is connected to the valve cover as a breather, but I thought I saw a few others, and I haven't followed them yet to see where they go.
Did you retain all of these when you did this kit? I have had issues before of getting oil in the intake and have wondered about just putting a breather filter on the valve cover fitting to avoid this. Is there any harm in doing that?
Old 11-29-2010, 08:46 AM
fordmdb's Avatar
PREMIUM SPONSOR
there are no pcv or other hoses on factory tube... those are all attached to the center box.
__________________
Old 11-29-2010, 10:53 AM
Quote:
Gotcha, I will be removing that center box though when I do mine. Do you think I would be OK to use a breather filter on the valve cover?
Old 11-30-2010, 12:22 AM
socapots socapots is offline
socapots is starting off with a positive reputation.
looks good man.
Old 12-05-2010, 01:34 PM
fordmdb's Avatar
PREMIUM SPONSOR
A few more shots before powder coating of pipe and before this thing is avail to public. We will also be working on a lid option too. Intake would work on all 6.2L Super Dutys and all 6.2L Raptors.
__________________
Old 12-05-2010, 07:32 PM
Gary Atsma Gary Atsma is offline
Gary Atsma is gaining momentum as a positive member of FTE.
Quote:
I think you would mess up the PCV system by doing that. You shouldn't have any oil in the intake if everything is hooked up right. Don't try to out-think the engineers on stuff like this. They have these emission systems pretty well figured out. I'm NOT saying things can't be improved (witness the above system), but you have to think everything through a lot more than in the not-so-distant past.
Old 12-08-2010, 03:27 AM
eticket eticket is offline
eticket is starting off with a positive reputation.
Mike (fordmdb)
Would this intake require a reflash or does ford PCM have "learning" ability?
I noticed you removed the factory resonators. Is the engine intake note comfortable
during normal driving and cruising? Thks...
Old 12-08-2010, 10:18 AM
fordmdb's Avatar
PREMIUM SPONSOR
Quote:
Originally Posted by eticket View Post
Mike (fordmdb)
hi eticket
I would recommend running a tune with any intake to take advantage of the modification. This one would be no different. Most intakes on the market use larger diameter tubes that tend to lean out fuel strategies. The larger tube also alters the maf function which in turns alters when to deliver fuel and timing to the engine. A calibration / tune is the only way to correct for this.. however with that said the PCM does have adaptive learning to help correct the lean condition but only up to a point.
As for sound, In cruising mode this intake has better than stock throttle response and is as quiet as stock and once you step down on it comes on strong with a louder than stock sound but again no problem with cruising sounds.
__________________
6.2L Intake fordmdb 6.2L V8 36 04-27-2014 08:59 PM
6.2L Gibson Exhaust fordmdb 6.2L V8 21 10-11-2011 06:26 PM
6.2L Towing 10k Lbs Video Part2 fordmdb 6.2L V8 23 03-22-2011 09:24 PM
5 Stars New 5.0L fordmdb 5.0L Coyote 199 03-21-2011 07:36 AM
Raptor 6.2 VS SD 6.2 fordmdb 6.2L V8 9 10-12-2010 08:01 PM
Tags
62, 62l, box, cover, delete, diesel, ford, install, intake, raptor, super, supertube, truck, tube, tubing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
